Right ok Yesterday i got my shiny new asus maximus extreme iv so thought i should probably put up some build pictures as i had to redo my H20 loop and cut my case up a Bit.
pic 1
the box
pic 2
Open the lid
pic 3
my other major components my lovely gtx 580 oc and 16gb of mushkin radioactive
Pic 4
i took this pic because i always mount the motherboard and then realise the I/O shield is sitting on the floor next to the pc and it drives me up the wall, not this time
pic 5
ram cpu and cpu block installed cpu is an intel core i5 2500k Previous best stable overclock 4.5 @1.35v on asus sabertooth p67. The cpu block is a Dtek fusion V1 with 1155 mountings and accelerator nozzle kit.
pic 6
pic 7
i tried to mount the radiator internally but my ram got in the way so i couldn't do push pull so i had to mount it on the top of the case which meant removing the top grill and cutting away some plastic, It actually looks quite good thought i think.
pic 8
this is once all the components are in the pc. i'll be honest it took me about 3 hours to do this i had to keep removing things becasue i wasn't happy but finally settled onthis configuration.
pic 9
last 3 pictures are of it all finished and in and running no leaks.
And yes i know i still haven't braided my pump cable
currently got my 2500k running at 4.73 but still working on stability
