Results 1 to 13 of 13
Thread: What Do Property Surveyors Look For?
    Stronger, by design. MagicEvie's Avatar
    Jun 2010
    Never Ever Ever Land.
    2,321
    450
    Default What Do Property Surveyors Look For?
    ... Apart from properties lol.
    We're re-mortgaging and the lender is sending a surveyor to look over our property. We should be fine as the value has gone up but I wondered if anybody has had experience of surveyors and how in-depth they scrutinise your property?
    My missus is treating it as if The Queen is paying us a visit
    New! ASUS P8Z-68 V-Pro, i5-2500k, Mushkin 120gb SSD, Samsung 1tb HDD, GTX 460 1gb, 16gb Corsair Vengeance DDR3 (4x4), Asus Xonar DG, Corsair H50, Win 7 Home 64.
    Ladies! If a man says he'll fix something - he will. He doesn't need reminding about it every six months, OK?
    aspdend's Avatar
    Sep 2010
    Chichester
    1,774
    201
    Depends on if it is a full survey or not - if it is not a full survey then it should just be a cursory look over the general condition of the building, looking for settling/subsidence, cracks in walls, where changes have been made, condition of window frames, guttering, downpipes etc - that sort of thing. Full surveys are the same but with more detail and closer inspections taking more time.
    720BE; GA MA790FXT-UD5P; 8Gb Mushkin silver; Sapphire 6950 (unlocked to 6970); TX850; 120Gb Mushkin Chronos; 8Tb HDD; 24" Ilyama Prolite; SteelSeries Ikari Laser; Saitek Eclipse II; FD Define XL
    Jun 2010
    2,321
    450
    Thanks aspdend. Sounds like we'll be OK then - after I've shifted some boxes in the garage to hide an iccle damp patch in a corner, that is!
    watercooled's Avatar
    Aug 2010
    Cheshire
    6,219
    673
    why what you hiding lol
    Is my new Kingston flash drive on drugs?
    i
    Banned
    May 2010
    Liverpool
    7,402
    692
    What Do Property Surveyors Look For.
    mainly your money
    between thoughts
    Sep 2011
    1,248
    120
    Depends on the surveyor, but a general thing to do is be ready for them to check everything.
    Military Grade Tester DoubleTop's Avatar
    Nov 2009
    In a lamp
    12,818
    135
    three kinds of report iirc,
    A mortgage report which to be very honest the surveyor doesn't even need to enter your house. This type of survey is all based on the asset that is the house, does the price being paid reflect the worth of the property should you default and the bank takes the house.
    Homebuyers report, as above for the bank, but also a little bit of looking under the skin of the house for potential problems. This may included comments such as "roof is original" or "signs of manageable damp", possibly a quick peek at the fuse box as well and pretty much all the things in a house that will surprise you once you've moved in.
    Structural survey, the man with a drill come in, measures damp levels in brickwork, takes up carpet to view direction of floorboards and supporting walls with reference to any internal layout changes. May also have a look at the sewerage if it's shared and runs across your property. This is the "daddy" of surveys, looking at all things that to me and you would be "things to get around to doing one day", lining chimneys, improving the energy efficiency rating.
    Hope this helps
    DT.
    Please see thread, here for how post reports are dealt with.
    Forum Guidelines here
  8. The Following 2 Users Say Thank You to DoubleTop For This Useful Post:
  9. #8
    Jun 2010
    2,321
    450
    Does help, thanks DT From what they've said and what you have said it sounds like it's the first option. Even if they do find something erroneous, worst case - it seems from reading up - is they'll recommend remedial works are done within a certain timeframe and I suspect a little damp corner in a garage on an exterior wall is something they come across fairly often. It's not as if the doors won't fit in their frames anymore due to subsidence or anything.
    *goes to open and close every door in the house repeatedly*
  10. #9
    hippo and pig fanatic waba's Avatar
    May 2010
    among many trees
    1,604
    197
    they are useless, they cant even lift up your floorboards...half the problems will be under there. if there is no ladder into the roof half of them dont go up. they might tell you the thickness of your roof insulation though...worth it for the money? :/
  11. #10
    Jun 2010
    2,321
    450
    Quote Originally Posted by waba View Post
    I'll let you know how good he is, waba. We have to endure this rigmarole as it's a stipulation of the remortgage.
    I'm not overly concerned tbh. We're quite lucky in so much as we inherited another property which we sold, and sold our previous house at profit 8 years ago and bought where we are now with only a 40% mortgage against the value of the purchase price of the property (lovely uninterrupted panoramic beach views ) I've done my homework - there is a website where you can see what properties sold for around you in the last few years and from that I can tell they've gone up about 50K. We're doing this as my wife is re-training so is effectively a student which was always the long term plan and we knew we'd lose her income for a few years but we could comfortably release equity from the property - if we bought the right place. Location, location, location as they say
  12. #11
    May 2010
    among many trees
    1,604
    197
    well, good luck with it all the mortgage companies always have it as a stipulation, i find it so funny though as they basically tell the mortgage company "yes, there is a house there". makes me think of solicitor fees...
  13. #12
    Jun 2010
    2,321
    450
    Money for old rope eh? Keeps someone in a job though I suppose
  14. #13
    GentleGiant's Avatar
    1,483
    48
    Most surveys are not worth the paper they are written on; I had THREE surveys done on my house before buying, and not one of them spotted the rampant woodworm or wet-rot in the dining room.
    When I say rampant, I went to remove a skirting board and it fell to pieces, the paint was the only thing holding it together. When I checked, you could push you fingers into it like it was a sponge.
    Married!!! despite every complaint they made about my paperwork, they finally gave in and issued our Red Books. (UK Consulate )
Watch Game of Thrones Online Game of Thrones S07E01 Streaming GoT Season 7 Streaming Game of Thrones Season 7 Stream game of thrones season 7 episode 1 stream got season 7 streaming game of thrones episodes download game of thrones season 7 spoilers game of thrones season 7 predictions viral viral news viral stories viral news today usa news usa news today dog meat ban yulin festival Watch Game of Thrones Online Game of Thrones S07E01 Streaming GoT Season 7 Streaming Game of Thrones Season 7 Stream game of thrones season 7 episode 1 stream got season 7 streaming game of thrones episodes download
