Page 1 of 3 123 LastLast
Results 1 to 15 of 37
Thread: Mushkin SSD problem
    Jul 2008
    520
    Default Mushkin SSD problem
    Hi
    My drive just arrived and i tried to install xp
    i get a hangup on windows setup blue page (nothing loads or anything)
    The sata controller bios recognises the mushkin as a sata drive
    but it does not seem to work. there is no light on the hard drive so i don't know if is functioning (its got slight movement that you con just about sense). iv spent entire day trying to put windows onto it. I cant figure out the problem
    LGA775 OC Legend
    Nov 2009
    Ringwood, Hampshire.
    4,645
    390
    You say you can sense a slight movement? That is not possible. There are no moving parts in a SSD.
    It seems odd that it won't detect though. You could always download a .ISO of Windows 7 and use that for 30 days if it will install. Have you got any methods of creating a bootable DVD or USB (4GB) stick?
    Griff's Avatar
    Aug 2011
    Walsall
    180
    "Slight movement" in a solid state drive?!?
    I've never tried installing XP on an SSD, seems counter productive, but I've installed Windows 7 on a variety of SSD's and never had any issues.
    Why not download a Linux distro and see if that will install on the drive. If that installs fine then you know the drive is ok.
    CPU - Intel i5 750 @ 4ghz, Mobo - MSI P55-GD80, Memory -
    8GB Geil Ultra Series PC3-17000, GPU - Nvidia GTX 570 SOC, SSD - Crucial C300 RealSSD,
    Display - Achieva Shimian QH270, Case - Corsair 600T SE
    Jul 2008
    520
    Quote Originally Posted by TheMadDutchDude View Post
    well it doesn't move ....but you know what i mean.
    I still have my sata HD that i am currently using
    i have a bootable winxp cd which works fine on HD drives
    how can i test the ssd drive?
    LGA775 OC Legend
    Nov 2009
    4,645
    390
    I don't know what you mean. Sorry.
    Well, you could boot up off of the HDD and check the SSD within Windows to see if you can put files on it etc. but I think it maybe an XP issue rather than the SSD. I could be mistaken though.
    Maybe it is time for you to move up ten years and on to Windows 7. XP is extremely dated now.
    Steam Joe90UK jason's Avatar
    Jun 2010
    2,059
    248
    Has it got the latest firmware? I'm not sure what it is but its worth a look use OCZ tool for sandforce chips to have a look.
    What port are you using if its not on an Intel port try it on one as marvel ports screw with SSD's.
    Sent from my Desire HD using Tapatalk
    CORE I7 920 OC 3.3GHz , Asus P6T , Patriot Extreme Performance Viper 6GB DDR3 PC3-12800C8 ,MSI 570 Twin Frozr III , Corsair TX Series 850W , Creative X-FI extreme music sound card
    OCZ Vertex 2E 60GB (boot drive)1X Corsair force 3 120GB, 1X 1T samsung F3 (backup)
    Jul 2008
    520
    well i was mistaken, the metal was vibrating from the case not ssd lol
    i attached ssd as a extra hd, it does not come up on my computer but it does come up on device manager under disk devices as a storage device
    jason i have tried lots of diffident ports ony my motherboard and my sata controller
    i am going to create a partition using norton
    as i am going to install two what sort of partition do i go for primary or logical
    Jun 2010
    2,059
    248
    So use disk management to format it and it should show up, then use OCZ tool to take a look at the smart data also update the firmware if its old.
    Aria Resident cinek's Avatar
    Nov 2010
    3,402
    644
    1. "Mushkin SSD" which one?
    2. Sounds like you have the same issues @Mikolaj had with his chronos. He updated the firmware and all is well
    3770k | MSI Twin Frozr GTX570 | Mushkin Blackline 16GB | Noctua NH-D14 | Samsung 840 Pro 128GB | Crucial M4 128GB | Gigabyte P67A-UD4-B3 | SoundBlaster X-Fi Fatal1ty Pro | Corsair AX850 | Fractal Design R3
    Jul 2008
    520
    ok xp setup is working know?
    i just put in the ahci driver floppy
    last time wondercat where here to help me out
    im in need of urgent help again
    thiere a dozen options for diffrent types of AHCI to chose from which one do i install?
    Added after 2 minutes:
    Quote Originally Posted by cinek View Post
    chronos 120 not delux
    please help asap.my install is still waiting
    Jun 2010
    2,059
    248
    Don't you have xp installed on the hdd? I think you should try to make sure the firmware is sorted before you install xp on it as updating it becomes a little more complex.
    Boot of the hdd and check the ssd.
    Jul 2008
    520
    Quote Originally Posted by jason View Post
    ok
    my mobo is msi p35neo2 and i think i need to choose
    ich9r ahci. first ill check firmware ...must rush back upstairs to other pc
    Jul 2008
    520
    well it seems that sandforce firmware update tool cannot find any drives
    Jun 2010
    2,059
    248
    Any thing in disk management?
    And you cant always update on ahci you may need to be In IDE mode.
    After downloading the firmware installation package, extract the zip file.
    Browse to the extracted folder and launch SF_FieldUpdater with administrative
    privileges. If SF_FieldUpdater is not launched with administrative privileges,
    the Chronos SSD(s) will not be discovered by the updater.
    Its the same updater as the one i used so it works in AHCI
    1.In Windows Explorer, click the program executable file that you want to open.
    2.Press SHIFT and hold, right-click the program icon, and then click Run as.
    3.To log on using an Administrator account, click The following user.
    4.In User name and Password, type the Administrator account name and password that you want to use.
    http://www.mushkingames.com/phpbb2/v...p?f=28&t=18507
    Jul 2008
    520
    i partitioned and formatted using norten magic
    it shows up as a local device on my computer and in device manager
    but not on sandforce live update and not on ms xp installation as a possible drive to install on
