Thread: Running two gfx cards
    Jun 2011
    Default Running two gfx cards
    Hey guys,
    I'm pretting new to the custom build pc scene and was wondering what the rules are on running dual gfx cards, like do they have to be exactly the same or can they be two different ?
    I already own a gtx 560ti twin frozr II but wanted the same card but the hawk edition and was wondering if i could run both cards or if i had to get the same one as i have now.
    Thanks in advanced
    Sweenster's Avatar
    Oct 2010
    Scotland
    139
    20
    As long as both cards are based on the same GPU it'll be fine. Any other 560ti will work in SLI.
    f12f12's Avatar
    May 2010
    london
    3,015
    332
    yes as long as its the same chip, if the frequency's are different then i believe it will slow the fast one to the slow ones speed.
    make sure its a 560TI and not just a 560, that wont work.
    also nvidia is SLI so make sure the board has a SLI licence.
    Thermaltake Element s - Q6600 @ 3.6ghz @ 1.48V - Corsair H50 - 6GB RAM - GTX260 192Core @ 729/1458/1224 - ATI 3450 - Biostar Tpower I45 - Corsair Force 60GB SSD - Samsung f3 500GB apps - Xigmatek 700W NRP-PC702 - 3x 17inch screens - windows 7 64bit
    Jun 2011
    so would i be able to run my 560ti and a 560ti hawk edition on this https://www.aria.co.uk/Systems/Bundl...roductId=44083
    f12f12's Avatar
    May 2010
    london
    3,015
    332
    yes. as long as the spec doesn't change any time soon.
    and what a hawk card? you will be limited by the slower one and even with noise the louder one will still be used.
    Jan 2011
    129
    12
    What PSU do you have?
    my iPhone is rattling Cleeecooo's Avatar
    Sep 2010
    Purley - Croydon
    1,235
    91
    Quote Originally Posted by f12f12 View Post
    he can always OC them both
    MY INTERNET IS BETTER THAN YOURS
    PROJECT:Temjin-M
    f12f12's Avatar
    May 2010
    london
    3,015
    332
    Quote Originally Posted by Cleeecooo View Post
    if the other one will match on speeds.
