Results 1 to 6 of 6
Thread: SSD and Samsung Spinpoint?
    Oct 2008
    32
    Default SSD and Samsung Spinpoint?
    Hi there,
    I've had recommended to me both the 1TB Samsung Spinpoint F1s, but also that I should consider (with my unmodest budget) investing in a SSD which I could stripe for my OS and bigger games, etc. I've a few questions, though. If I were going to get a SSD, I'd probably invest in one of these OCZ 64GB drives - but I don't really know what the difference is (other than 4GB of space) between the OCZ 64GB Core Series SSD and the OCZ 60GB V2 Core Series SSD which is about £25 more expensive?
    Also, would this combination of drives be a good idea? Could I put them in a RAID0 array (or similar)? How would I want to do so? (or how would I want to stripe them?) Etc.
    Edit: Or, for that matter, would I be better off, you think, just buying a couple of the Samsung Spinpoints (or sim.) and not going SSD at all, at this point?
    And advice at all would be eagerly welcomed and appreciated!
    -RoA
    Lynx's Avatar
    Aug 2007
    3,446
    35
    SSd's are a bad idea, unless you have a lot of money to burn, you should not worry about SSD's, get a couple of F1's in a raid setting if you really want performance and space on a budget, until SSD's come down in price, leave them be lol.
    Samsung Galaxy S : Member 8
    Oct 2008
    32
    Quote Originally Posted by Lynx View Post
    that was kind of what I was thinking, looking at the £170 pricetag on that SSD! I'm grateful for the advice!
    Thanks,
    -RoA
    Lynx's Avatar
    Aug 2007
    3,446
    35
    You will spend a bit less on two 1TB F1's and will get amazing performance and far more space.
    110
    High read/write speeds are one thing, but these come at a cost with RAID - latency.
    I've found through my research that games that continually load benefit from lower latency rather than higher read/write speeds. MMOs run amazingly well on my SSD.
    Q6600 @ 3.6 GHz | 4GB PC2-6400 | MARS P35
    8800GT (PhysX) | 9800GX2 | X-Fi FATAL1TY
    2x 150GB Raptor (RAID0) | 60GB OCZ V2 SSD
    Antec P182 | 850W OCZ
    Devil's Advocate marsey99's Avatar
    St Helens
    17,918
    2,572
    games fullstop run faster on ssd.
    the 0 seak times do wonders as games load lots of smaller files.
    we know who we are,
    most successful english football team ever, liverpool fc.
    we know who we are.
