Results 1 to 6 of 6
Thread: graphic card making a rattling noise
    Aria Resident cinek's Avatar
    Nov 2010
    3,395
    644
    Default graphic card making a rattling noise
    Finally remembered to check where the noise is coming from (after waking up) and it turns out it's one of the fans on the graphics card, not the sound card. It's defo the fan as when I stop it, the noise stops too. Should I RMA it?
    3770k | MSI Twin Frozr GTX570 | Mushkin Blackline 16GB | Noctua NH-D14 | Samsung 840 Pro 128GB | Crucial M4 128GB | Gigabyte P67A-UD4-B3 | SoundBlaster X-Fi Fatal1ty Pro | Corsair AX850 | Fractal Design R3
    Ninjago's Avatar
    Jul 2011
    104
    Sounds suspiciously like a problem I had with a GTX260 - turns out that the fan itself had actually split and the force of it turning was pushing one of the fan blades fractionally off so that it hit the plastic casing. Sadly mine was out of warranty, so we had a go with some glue and fixed it! But if you can return it, do so (I bought a new card so that I wasn't running one held together by Loctite).
    Nov 2010
    3,395
    644
    thanks, but it only happens on cold boots, it stops after about 30-40 seconds
    Josh's Avatar
    Sep 2010
    Walkden, Manchester
    5,120
    1,185
    Moved to graphics card section as requested
    May 2011
    114
    20
    I may be completely off here but have you checked if any wires are catching on the fan?Its just i had a similar problems with CPU cooler fan and it was a simple fix after and initial panic
    AMD Phenom II X4 965 Black Edition(CM Hyper 212 Plus) ASUS M4A89TD PRO| 8GB 1333MHz Mushkin silverline | Asus 6770 | 128GB M4 (1TB WD Caviar Black)| 750W XFX core edition |CM690 II Case
    Ninjago's Avatar
    Jul 2011
    104
    Quote Originally Posted by cinek View Post
    Yeah, this only happened on cold boots as well - until I whacked it up to 100% in RivaTuner. Then there was a very big noise, and after that it made the noise all the time. Whoops...
