Results 1 to 15 of 19
Thread: My Washing Machine Caught fire!
    Jun 2010
    Northampton
    1,047
    263
    Default My Washing Machine Caught fire!
    Anyone know what this can be? There was water on the floor, smoke started coming out of it.
    I panicked and tried to yank it from under the kitchen top and pulled out the mains cable whilst try to get it out. At first I couldnt get it to switch off so I turned off the mains. My house stank of smoke for several hours after. This was on saturday evening.
    Survives the Apocalypse Broadsword1976's Avatar
    Feb 2008
    Torquay
    5,235
    1,293
    7
    Fairly serious motor in a washing machine I guess...I'd imagine it burnt out...Good job you were about tho' eh?
    Gigabyte 990FXA-UD5.AMD FX8150 @3.5Ghz. 8Gb Mushkin Redline, MSI 7950 TFIII BE, 120Gb Mushkin Chronos + 256Gb Crucial M4 + 2x2Tb F3 Spinpoint Eco-Greens + 1x 3Tb Seagate. Antec 900 Watt PSU . Windows 10 Pro
    Jun 2010
    Northampton
    1,047
    263
    Quote Originally Posted by Broadsword1976 View Post
    we very often go out after turning it on. i dont think we will ever do that again.
    Reako's Avatar
    Apr 2011
    Warrington
    199
    im only 26 years old and i been throu about 12 washers
    Jun 2010
    Northampton
    1,047
    263
    Quote Originally Posted by Reako View Post
    did any of them catch fire? did you not think of getting them repaired or was that too costly?
    12 washers? sorry but i find that slightly amusing.
    GentleGiant's Avatar
    1,483
    48
    Is it a washer/dryer?? These go up quite often if you dont open them and inspect for fluff build up inside once every year or so.
    Small amounts of fluff always get through the filter, and when the filter gets a couple of years old it may develop small cracks, which let even more fluff through; or get displaced slightly, which lets a LOT of fluff through.
    I had one go up while I was testing it, so got the fire out quickly; when I opened it there was a 2" thick wad of fluff built up inside that was just touching the heater element
    (Dont believe me?? Ask a fireman)
    Married!!! despite every complaint they made about my paperwork, they finally gave in and issued our Red Books. (UK Consulate )
    Reako's Avatar
    Apr 2011
    Warrington
    199
    Well i have had this problem with smoking washers but my girlfriends dad does refrigeration and always manages to fix them but if not be brings us a new one the next day he gets them really cheap and has a warehouse full of them
    http://regener8.org.uk/ i made him this website when i first started web design lol pretty crap
    Jun 2010
    Northampton
    1,047
    263
    Quote Originally Posted by GentleGiant View Post
    its not a combo just a washing machine
    Dec 2009
    521
    Knew somebody who had that, if it was not for the quick thinking of her other half could have burnt the whole house down and them with it as it was left un-attended so his quick actions and the quick response of the fire-brigade saved the day to a degree.
    I believe only the utility room area badly burn't out... but was so close to being something far more devastating.
    #ShrubberyMod Black Knight's Avatar
    None shall pass
    19,361
    2,511
    Fascinating and gripping stuff this.
    Would read again.
    My local hospital has a sign which reads "This way for accidents and emergencies." Haven't people in hospital got enough to worry about without looking for further misfortune?
  11. The Following User Says Thank You to Black Knight For This Useful Post:
  12. #11
    Jun 2010
    Northampton
    1,047
    263
    sounds like a commone problem then. anyone know how to fix it to save my landlady a few quid?
  13. #12
    Forgetful much~? FunkY's Avatar
    Mar 2011
    Surrounded by trees...
    5,686
    1,078
    I've swapped out broken pumps for new ones before now, never tried replacing the main motor though (never had one die)... Shouldn't be too dificult as long as you don't have to remove the whole drum assembly. Just make sure you disconnect from the mains and watch your back, the concrete weights that hold them in place tend to be heavy
    Also keep a note of where everything goes, so you can put it all back together and feign ignorance when you're telling your landlady it's broken.
    Don't tell her you tried fixing it (unless she's asked you to obviously)
    Why did the chicken cross the road?
    To get away from the Canadian poultry farmer with loose trousers.
  14. The Following User Says Thank You to FunkY For This Useful Post:
  15. #13
    1,483
    48
    The motor is usually mounted independently of the drum, so no need to touch it, ditto the concrete blocks.
    It is fairly easy to remove once you have the machine upside down; just make sure you get the belt aligned and tensioned.
    BUT!
    Before you do that, you need to discover why it went up in flames and if the motor is indeed the problem.
    As I mentioned above, turning the machine upside down is often the best way to get access; have a good look to see if you can spot any damaged areas, and any place the water might be coming from. I suspect the smoke was from melting plastic, so look for a melted plastic water pipe, whatever was over heating will not be far away.
    (I used to buy and repair scrap washers for extra income)
  16. The Following User Says Thank You to GentleGiant For This Useful Post:
  17. #14
    Jun 2010
    Northampton
    1,047
    263
    i told my landlady i might have a look but its not my thingand that i do computers not washing machines. Shes a nice lady and very generous, not the stereotypical landlord/lady.
    Im feeling terribly lazy atm prob cos i have a cold but will get up later to look to see what part got burnt.
    I think you are prob right gentlegiant, whatever caught fire could have melted the water pipe. the water prob put out the fire as well as it stopped burning. i did swich off the mains as well.
  18. #15
    1,483
    48
    Assuming you do find the problem, dont try to turn anything on until you are certain you have dried it out thoroughly, the logic boards can cost MORE than a whole machine to replace, (got quoted 299 + P&P for a replacement Z****i logic board for a 300 machine)
  19. The Following User Says Thank You to GentleGiant For This Useful Post:
Watch Game of Thrones Online Game of Thrones S07E01 Streaming GoT Season 7 Streaming Game of Thrones Season 7 Stream game of thrones season 7 episode 1 stream got season 7 streaming game of thrones episodes download game of thrones season 7 spoilers game of thrones season 7 predictions viral viral news viral stories viral news today usa news usa news today dog meat ban yulin festival Watch Game of Thrones Online Game of Thrones S07E01 Streaming GoT Season 7 Streaming Game of Thrones Season 7 Stream game of thrones season 7 episode 1 stream got season 7 streaming game of thrones episodes download
