Results 1 to 14 of 14
Thread: How do i get wireless broadband on my laptop
    Enthusiast
    Dec 2006
    51
    Default How do i get wireless broadband on my laptop
    Right i have a laptop and now i want to put wireless broadband on my laptop, how do i go about this??? any info on products would be great thank you!
    Moderator wonderlust's Avatar
    Swale, Kent
    16,863
    273
    Has the Laptop built in Wireless Lan?
    Which Router do you have?
    I am not losing weight! I'm getting rid of it. I have no intention of finding it again!
    Growing old is inevitable. Growing up is optional
    Enthusiast
    Dec 2006
    51
    Its a dell inspiron 1525, it has a Integrated 10/100 LAN (RJ45) and 56K Modem (RJ11)
    Swale, Kent
    16,863
    273
    could you provide the dell tag number?
    The reason for asking is that the model you have can have any one of 2 different wlan cards installed
    Jun 2008
    Barrow-in-Furness (Lancaster University)
    506
    Assuming you're running under windows
    Go to start->run
    Type services.msc. Check that "WLAN autoconfig" (Vista) or "Wireless zero service" (XP) are enabled and automatic.
    Once that's on you should have a lan-style icon (Just a normal network connection on Vista, a single computer with some "signal" lines on XP). Just right click on it and choose "Connect to a network" (Vista) or whatever the option is in XP (It'll be fairly obvious)
    Then just enter the SSID and key for your router and Bob's your mother's brother.
    Jon
    AMD Phenom II 720BE 2.8gHz@ 3.6gHz | TRUE & noctua 120mm
    Biostar ta790gx3 a2+ | 4gb Kingston HyperX PC2-8500
    Asus geForce GTX460 768mb - 22" LED monitor @ 1920x1080
    1TB+2TB Samsung F3 | Antec 300 | OCZ modXstream 500W
    Swale, Kent
    16,863
    273
    He may need to enable it first via the function keys, (why i asked for the tag, to find out which card is installed)
    He may have to enable the Wireless Access point on his router, plus may have to add mac address to the ACL.
    He should also set up security, at least wpa.
    Enthusiast
    Dec 2006
    51
    Quote Originally Posted by wonderlust View Post
    Ummmm right ok where do i find this from?
    Swale, Kent
    16,863
    273
    Should be a sticker on the bottom, they used to end in a J
    Enthusiast
    Dec 2006
    51
    the service tag is bxpyf3j
    Swale, Kent
    16,863
    273
    Ok, thank you, you have the DELL WIRELESS 1390 802.11B/G MINI-PCI CA fitted as standard.
    Let us know when you have it on, you can check device manager to see if it's on before you start.
    You may need to turn this on, there should be a symbol on the keyboard with a FN toggle to turn it on and off.
    Enthusiast
    Dec 2006
    51
    Right its on i believe
    Swale, Kent
    16,863
    273
    Ok do you have a wireless access point or a wireless router?
    Enthusiast
    Dec 2006
    51
    well i did have a router but its not compatable with vista! cud u recommend one for me?
    Swale, Kent
    16,863
    273
    what make model is it?
    Routers are normally OS independant.
