Hi i posted this over at some AMD forums but though the more minds on it the better
so heres my problem
First of all this is my current setup
[CPU] AMD Athlon 64 X2 4200+ (AM2)
[Motherboard] As-Rock AM2NF4G-SATA2
[Power supply] Hipper HPU-4S525 (525W)
[Memory] Corsair Value Select 1GB DDR2 667
[HDD] 300GB Maxtor Diamond Max Sata II
[DVD-R/W] Lite on DVD + - r/w dvd Ram drive (model unknown)
[DVD] Sony DVD rom drive
Firstly
I bought the bits from a computer store near me yesterday, spent all last night backing up and then set out to build this morning. Emptied my case and cleaned out well.
(DVD drives and fans were left in)
Put motherboard in and connected up the power, switch, reset buttons ect & front USB's
Put power supply in and fastened in position,
Put cpu in and Heatsink (after figuring out what the big lever does on the side of the heatsink)
Inserted hard drive rack
Inserted floppy drive rack
Connected things up to power and M/B
Turn on
And nothing happens. I then restart and it comes up.
Did this a few times but ever time it didn’t boot into bios first time. Had to be turned on and then hit the reset button.
Then I get boot failure, obvious I have to reinstall windows xp so, I go through the beginning of the pain full process, hit f6 to install a 3rd party or raid driver. Insert the floppy and setup says there is a file missing.
As I type this I am currently formatting My sata hdd. I managed to get past the problems I encountered before but I am still having trouble booting,
if it is being switched on then 99 times out of 100 ( I haven’t actually tried it that many times although it feels close) it wont boot into bios, and I have to hit restart button for it to work, although this only works around 7 out of 10 times.
just a few slight notes, the back plate - some of the little metal tabs that touch around the Ports (USB, Parralel, PS2 ect) aren’t touching, there fore I don’t think they are earthed. I don’t think this would effect it, ever since I got the case it has always seemed Slightly out of shape. Just thought I’d add that.
So, trouble booting into bios, sometimes boots some times doesn’t, oh and I don’t hear any beeps.
Any help would be very much appreciated
Lewis
- Update when windows Xp finished the first part of the setup, as usual it goes to reboot, so it re boots and it doesn’t. Nothing on the screen.
- Update 2 Got xp installed, but still doesnt boot bios when i turn on
any help from you marvelous guys (and gals) would be really great, i really wanna stick my AMD 64 case badge on, but i am not doing until i have got it working. very stuborn i am
Cheers
Lewis :wink:
(on laptop at the moment)
