Results 1 to 15 of 17
Thread: Can anyone recommend a silent 80mm cpu fan?
    Einholt's Avatar
    Jan 2011
    1,135
    134
    Default Can anyone recommend a silent 80mm cpu fan?
    Hello all, got a CM TX3 and the fan that came with it is very loud and responsible for 90% of the noise in my case, can anyone recommend a good 80 mm silent one that still preforms well at cooling?
    1,859
    38
    80mm is quite small to make a quiet/silent fan, it has to spin at high rpm to move a worthwhile volume of air. If you can afford it, save yourself a lot of hassle and upgrade to a heatsink with a 120mm fan.
    If you insist on sticking with 80mm, you could try something from Noiseblocker, Noctua, Be Quiet! or Scythe
    ACSS Telecoms Engineer Pepp77's Avatar
    Aug 2010
    3,156
    170
    The Xilence redwings are pretty quiet, as are the Lian Li fans I got with my V351 case. Or maybe the Noctua ones.
    Einholt's Avatar
    Jan 2011
    1,135
    134
    ooops meant 92mm, I'll check out some of those fans.
    ( ͡° ͜ʖ ͡°) Sarky's Avatar
    Jan 2011
    Leeds
    6,234
    1,509
    I'll keep an eye on this thread then too, because my CM Vortex Plus cooler came with the same fan as the TX3, so I know what you mean.
    Its only quiet on idle, full load is a vacuum.
    Dell Inspiron 15SE: i7 3612QM | 6GB RAM | 7730m | Samsung 840 250GB | Samsung M8 1TB | Dell U2312HM | Zowie EC2 | Creative Inspire T10 | Corsair HS1A
    My Flickr
    Canon 550D | Tamron 17-50mm f/2.8 | 55-250mm f/4-5.6 | 50mm f/1.8 | Lowepro Nova 160AW |
    Einholt's Avatar
    Jan 2011
    1,135
    134
    Just been fiddling and found lowering the fan speed down to 2000 rpm has a dramatic effect on the noise, it was at 3000 rpm idle, now will 2000 rpm be ok when gaming in a well ventilated case? the other fans are all operating at 1200rpm which seems to be there maximum.
    Jan 2011
    Leeds
    6,234
    1,509
    Mine's running 2000RPM on idle, rising to about 3000RPM full load. What CPU are you running?
    My Flickr
    Einholt's Avatar
    Jan 2011
    1,135
    134
    i5 2500k
    Mine seems to run at 3000rpm all the time, how do I stop it from doing this?
    Jan 2011
    Leeds
    6,234
    1,509
    Change the fan control in the BIOS to PWM or Auto, thats what I've done. You might have to enable hardware fan control though.
    My Flickr
    Jan 2011
    223
    ?? I got the same cooler, and mine is very quiet. What is wrong with your system? high temp?
    Mine now is on 1800rpm @36C on i7-860 idle.
    nothing will be slient at 3000rpm btw
    Einholt's Avatar
    Jan 2011
    1,135
    134
    Well as I said I lowered it to 2000 rpm and it is still very noticable, 'tis ok, going to get a gelid tranquillo at some point, read about 15 odd reviews today and that seems to be the best cost / performance cooler that is also outstandingly quiet.
    Jan 2011
    Leeds
    6,234
    1,509
    I don't have that choice, because the max height my case can accommodate for a CPU cooler is 126mm
    My Flickr
    Einholt's Avatar
    Jan 2011
    1,135
    134
    Quote Originally Posted by Sarky View Post
    removed competitor link
    How much do you love me?
    Jan 2011
    Leeds
    6,234
    1,509
    Still don't . The Vortex Plus fan mounting system is two clips which fit in the 92mm fan holes. They look like this (bottom right thin wires)
    My Flickr
    Also known as Merlin 633Squadron's Avatar
    Nov 2010
    954
    101
    Aren't all broken 80mm fans silent.......??
    /runs away quickly
    Creator of the Retr0bright Wiki - www.retr0bright.wikispaces.com and Admin at www.amibay.com - the retro computer trading forum - and Bigian88's Dad.....
