Results 1 to 2 of 2
Thread: Wanting 2 network my home .. need ideas
    Sep 2007
    Wolverhampton
    34
    Talking Wanting 2 network my home .. need ideas
    Hi
    I have Virginmedia broad band conected to 1 computer in my house.
    I want to have a laptop and be able to access the internet from anywhere in my house.
    But I also want to be able to access all he music and video files on my main computer.
    I have noticed things like 1TB Network Hard Drives - is is just a case of copying all files I want from my main computer on to one of these so I can access the info?
    Can't I have direct access to my main PC and if so does it always have to be switched ON?
    The laptop will primarily be for my daughter so she can access the internet and play games in her room, so I want to be able to connect it to her TV. She plays Lord of the Rings Online, could she still do this in her room as the game is set up on my main PC or is it just a case of installing it on the laptop and playing as usuall?
    Finally, could you give me some idea of what I would need - hardware to set up a network -(wireless I think is easier) and what sort of laptop would be good enough to play LOTR Online?
    Many thanks.
    Simon Janda
    System:
    MB: MSI K8N Diamond nForce4 SLi
    CPU: Athlon x64 4200+ DualCore
    Ram: 2x 1g Corsair XMS
    GPU: MSI NX8800GT 768mb
    PSU: Corsair 620w HX V2 Modular
    HD: SATA300g; SATA2 250g; IDE80
    OS: Win Vista Home Premium
    k.jacko's Avatar
    Feb 2008
    Nottingham
    382
    Quote Originally Posted by simonjanda View Post
    Hi
    Hi Simon, first you need a wireless router, preferably with 4-port switch, like the Linksys WRT54gs (although old, its still a good piece of kit). I use one in my loft and it supplies the whole house with a good wifi signal.
    You can get a NAS (network attached storage) drive like the one you suggest that just attaches to the network without the need of a pc(router/switch) via a cat5e cable, and yes, just copy the files over from your pc to that. An external usb hard drive would still require your pc to be always on, so that's a no-no!
    You can have access to your main pc from your laptop, by setting up a 'share', but it will always need to be on to share the data thats on it. Or, see the point above regarding NAS.
    Ok, to connect it to a tv, you need to know what interconnects the TV has first (vga? scart? composite?). Then you see what the laptop has (vga, s-vid) and find an appropriate cable to suit your needs.
    To play LOTR she needs it to be installed on her laptop, so make sure you buy one that can handle the game. You can't programe share it from your pc.
    To reiterate:
    • Wireless router
    • Some cat5e cable
    • NAS (500gb should easily be enough for 2 of you)
    • wifi enabled Laptop (with s-video out), good enoguh to play LOTR, (too many to list, ask in a shop)
    Hope it helps. LEt us know who you get on, or if you have more questions.
    - Jacko -
    Corsair 600T (white) | 24" tft @ 1920x1080 | Corsair AX850 mod. | Asus P8Z68-V Pro | i7 2600k @ 4.5GHz | 12Gb Corsair 16000 | Vertex 3 120Gb | HD6950 2Gb | Win7 Ult. x64
