Thread: Wried or Wireless
    Default Wried or Wireless
    My house mates currently have a Linksys Wireless-G ADSL Gateway router. How does a router effect internet speed if at all? Is it more reliable and faster for me to connect via cable or is wireless just as good?
    Firerat's Avatar
    832
    Personally I would go Wired given the option.
    But having said this Wireless has greatly improved.
    I recently installed a D link Wireless G ,to feed a Wii,and I have to say I'm very impressed with the speed. Somehow internet browsing seems faster on the Wii than the PC the Wireless router is hooked up to!!
    Lynx's Avatar
    Aug 2007
    3,440
    34
    If you buy cheap wireless or cheaper wire, the wired version will win. If you buy expensive wired, it will not beat cheap wired... But thats dependant on so many factors. Thick walls will ruin your speed, and wired can have some DHCP problems sometimes, even when setup properly.
    Samsung Galaxy S : Member 8
    cleggypdc's Avatar
    Aug 2007
    921
    wired for main desktop pc, and wireless for laptops etc.
    May 2007
    I live in a tree
    308
    With my current setup in MOST rooms of the house...
    1ms to ping router on wireless
    pretty much 0ms on wired.
    effective speed on wireless 3.2MB/s (connection at 54mbps)
    effective speed on wired 11.8MB/s (connection at 100mbps)
    It all depends on the hardware you have really. For most things wireless isnt that different these days.
    Lynx's Avatar
    Aug 2007
    3,440
    34
    If your on a gigabit router then even better. Im on a 10mbps router switch, but get over 1mb speeds on it, confusing, i need a new switch put in.
    Mar 2008
    I am a Telecom Engineer and wired is the faster, more secure and
    more reliable way to go. It is time consuming to hard wire an entire house
    but once it is done, you have a fast and reliable connection
    anywhere you go. It is easy to do, just get a network starter kit and
    off you go.....
    Hmmmm tystar's Avatar
    Sep 2007
    7,198
    143
    Or just get some homeplugs, best thing since slice bread. Would be lost without mine.
    neater than cabling a whole house and better than wireless.
    2007 - Present day.
