Page 1 of 3 123 LastLast
Results 1 to 15 of 45
Thread: build me a PC of £500
    Jul 2006
    Default build me a PC of £500
    i was wondering if someone could help, buy telling me what i exactly need to build a pc, to max out the £500 to get the maximum from what i can spend thank you.
    What do you intend using it for?? Gaming? Multimedia? Office work? Video editing type stuff?
    Need a bit of background as to what you intend doing with it, i could spec you something with a £200 graphics card in and then find out you don't play many games on it and the money would have been better spent on more storage etc etc.
    Mentor Barley's Avatar
    Popovka
    763
    Yep, we need to know what you want to do with the system, and whether or not you have any parts already? Do you have a keyboard, mouse, monitor? If so you can use them and add more money to important components.
    Jul 2006
    thanx for your reply, well if this helps i would like the pc to run for a couple of years with out changing much of it, thanx again for your help.
    Forum Addict
    Jul 2006
    177
    Presuming you've got keyboard, mouse, speakers etc. and play some games:
    Athlon X2 4200 Socket 939 (£146)
    ASRock 939Dual-SATA2 Socket 939 (£39)
    Corsair Value Select 512MB PC3200 VS512MB400 x2 (£62)
    160GB Seagate Barracuda 9 SATA-2 (£49)
    Enermax Liberty 500W Modular PSU (£69)
    Approx. £372 Total inc shipping.
    Sapphire X1800GTO 256MB PCI-E £132 Total inc shipping (Aria don't stock these cards)
    £504 TOTAL - close enough :wink:
    *The motherboard will allow you to use an AGP graphics card if you currently have one. Otherwise, you can choose another motherboard with a few more PCI-E slots.
    If you need a case, you could get a slightly cheaper PSU (Antec, Enermax recommended) and a smaller size HDD.
    C2D E6300 : Foxconn P9657AA-8EKRS2H : 2GB Corsair DDR2-667 : Sapphire X1650XT : 320GB Seagate 16MB 7200.10
    Jul 2006
    erm well i need everything so from scratch if go over by £50 it doesn’t matter, thanks for you help ppl, much appreciated
    Popovka
    763
    Well that makes a huge difference because you need a monitor and case. Including them, I doubt you'll have a PC that can play any new games, unless you source some parts from eBay on the cheap.
    This includes everything you will probably need to do a bit of upgrading in a few months to a year depending on what you do, ie the gfx isn't great so if you find that game you really want to play is stuggling then graphics card / memory might need upgrading that type of thing also the monitor isn't massive but it should suffice again you could get a bigger one when / if needed when funds allow. Also i have added a different one to the one supplied in the 4 in 1 pack as i wouldn't trust a bundled psu as far as i coul throw it these days but it's upto you, you could go with the bundled one and spend the extra ££ elsewhwere upgrading something.
    Forum Addict
    Jul 2006
    177
    Alien Custom Case Silver (Zorro Design) (£27)
    Keyboard, Mse & Sp'ks (Black/Silv) (£7) Would be sufficient to get you started
    £538
    If you don't have a monitor, then the cheapest option would be one of the Dell 17\" CRT's. That would probably knock up your shipping a bit too. You could always downgrade your cpu to an Athlon X2 3800 which would save you roughly £30/get you a CRT monitor. The X2 3800 is still a fantastic processor!
    If you don't like the speakers, then just get keyboard, mouse and a nicer speaker set seperately. The keyboard and mouse are cheap. The speakers depend on quality. Anyway, that's a rough guide. Tell us what you think.
    ADD: Sorry I forgot about your DVD-RW.
    NEC ND-4571 LabelFlash (£25)
    Looks like you may want to just get 512MB RAM. Things like RAM can be added to at a later date anyway. Approx. £508?
    Jul 2006
    how much would i need to spend for a pc that would last me a long time without breaking the bank?????
    Forum Addict
    Jul 2006
    177
    I'd say £550-£600, depends what you class breaking the bank as.
    Forum Addict
    Jul 2006
    177
    This looks good to me:
    Athlon X2 3800 (£117)
    ASRock 939Dual-SATA2 (£39)
    Seagate 80GB SATA2 8MB Cache HDD (£35)
    Silver Floppy Drive (£5)
    Corsair Value Select 512MB VS512MB400 (£31)
    NEC ND-4571 DVD-RW LabelFlash (£25)
    Any quality 450W+ PSU (Antec, Enermax etc) (£50-£70)
    Alien Custom Case Silver (Zorro Design) (£27) (Also possible to source a Jeantech G-Max Case from ebay at under £20)
    Dell 17\" CRT Black monitor (£50?)
    Sapphire X1800GTO 256MB PCI-E (£125) (Can find elsewhere)
    Windows XP Home OEM (£56)
    Keyboard, mouse, speakers - you decide.
    That should be everything.
    £590 max total exc. shipping. (exc. mouse, keyboards, speakers)
    Hope that helps.
    17inch TFT http://www.aria.co.uk/ProductInfoComm.asp?ID=22833
    AMD 3800 X2 http://www.aria.co.uk/ProductInfoComm.asp?ID=19392
    120GB HDD http://www.aria.co.uk/ProductInfoComm.asp?ID=14774
    1GB Memory http://www.aria.co.uk/ProductInfoComm.asp?ID=20235
    Gigabyte https://www.aria.co.uk/ProductInfoComm.asp?ID=21420
    NEC DVD/RW http://www.aria.co.uk/ProductInfoComm.asp?ID=22747
    Windows XP http://www.aria.co.uk/ProductInfoComm.asp?ID=2048
    Case https://www.aria.co.uk/ProductInfoComm.asp?ID=21645
    Graphics Card https://www.aria.co.uk/ProductInfoComm.asp?ID=23628
    Power Supply https://www.aria.co.uk/ProductInfoComm.asp?ID=19633
    A very stable build. Comes with a 17ich TFT monitor, Dual Core processor, 1GB of Memory, Windows XP, high quality power supply, and even a pci-e graphics card.
    For around £550 delivered 8)
    With an extra £50 upgrade to either 2GB if you do alot of muilittasking and not alot of gaming. If you like gaming then upgrade the graphics card.
    Firerat's Avatar
    832
    [quote:8ca4574a64=\"mac124\"]
    This includes everything you will probably need to do a bit of upgrading in a few months to a year depending on what you do, ie the gfx isn't great so if you find that game you really want to play is stuggling then graphics card / memory might need upgrading that type of thing also the monitor isn't massive but it should suffice again you could get a bigger one when / if needed when funds allow. Also i have added a different one to the one supplied in the 4 in 1 pack as i wouldn't trust a bundled psu as far as i coul throw it these days but it's upto you, you could go with the bundled one and spend the extra ££ elsewhwere upgrading something.[/quote:8ca4574a64]
    you missed the HS/Fan for the OEM CPU
    http://www.aria.co.uk/ProductsList.a...SubCat=FAN-939
    Firerat's Avatar
    832
    Just had a thought,
    Can you install XP SP2 on a SATA drive without a floppy drive these days?
