Results 1 to 6 of 6
Thread: wireless - help!
    Nov 2007
    Default wireless - help!
    I bought Lantech Wireless 54Mb B/band Router - 54Mbps Wireless USB adapter WL54G-BR + WL54G-USB PRO 8810-663A + 8810-634 from aria to set up wireless from my ntl broadband. I've wired the router to my pc and works fine wired, when i go to configure the router as per instructions (open browser. In address box type http://192.168.1.254) the browser doesnt display as shown, it has boxes instead of english with the odd identifiable word, so i cant configure it to use as a wireless router!
    Can anyone help!!!
    Lea
    Flight Simulator X Captain
    Sep 2006
    3,956
    ok leave the router plugged in, look at the back and hold the rest button in for 30seconds.
    Leave it for another 30seconds, take the plug out, wait 30seconds, plug it back in wait 30seconds again then try again. If it continues then post an image of what your seeing.
    Can you try accessing the Router from another PC?
    Nov 2007
    thanks Mickey007, have followed your post but still getting same issue attached below.
    設定精靈
    設定精靈將會引導你首次組態無線基地台,請依照設定精靈步驟.
    1. 選擇你的時域
    2. 設定區域網路介面
    3. 設定外部網路介面
    4. 無線網路區域網路設定
    5. 無線網路安全設定
    I'm The Best
    Oct 2007
    Liverpool, UK
    3,360
    163
    An internet translator returns : Hypothesis demon The hypothesis demon will be able to guide your for the first time configuration wireless base station, please will defer to the hypothesis demon step 1. chooses your time domain 2. to establish the region network to lie between surface 3. to establish exterior network to lie between the surface 4. wireless networks regions network to establish 5. wireless networks safe hypotheses
    www.world.altavista.com/tr Chinese traditional to english
    Pentium G620T | ASUS P8H61-I | 4GB Patriot 1333Mhz | 64GB Cruical M4 | Antec ISK300-150
    Member jman's Avatar
    27
    anyone else thinking the language is set to something other than english? looks a bit odd anyway. if the hardware reset doesn't help - um - RMA it or find someone fluent in Mandarin / Cantonese?
