- Rep Power
- 0
TP LINK TL-WN650G Problems!
I have just purchase the above card to connect to my BT Home Hub, its seems to have installed and be physically working ok, but it doest seem to be able to aquire network adresses! It shows full signal strength but it just shows limited or no connectivity. I have tried using both the software that came with the card and XPs own wireless connectivity software. I even tried connecting to another unsecured wireless network and it wouldn't do this either. Any ideas? Are there known issues with this card or anything???
- Rep Power
- 1
Try pressing the wireless connectivity button on the back of the BT Home hub, then using the XP wireless to connect. This allows the two devices to pair.
OR...
Try these drivers
http://www.tp-link.com/support/downl...TL-WN650G&h=V1
- Rep Power
- 0
Re:
[quote:0f68a25b65=\"cleggypdc\"]Try pressing the wireless connectivity button on the back of the BT Home hub, then using the XP wireless to connect. This allows the two devices to pair.
OR...
Try these drivers
http://www.tp-link.com/support/downl...TL-WN650G&h=V1[/quote:0f68a25b65]
I have just been trying to connect in this way.
installed only the driver + tried to connect via windows. The network is found, I click connect, enter the WPA key and ok but it just tries for a while to connect then the box disappears and it hasn't connected.
any ideas? :? :?
- Rep Power
- 1
have you contacted BT to see if your BT box supports this card
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
