here the starter, gigabyte 3d aurora in black,3 x 120mm fans, holes ready for watercooling kit laterand under budget
http://www.aria.co.uk/Products/Compo...roductId=21600
i3 2120 , Asus P8Z68-v/Gen3, 16gb Geil Black dragon, 128gb Crucial M4 ssd, 4.5tb storage, Asus Xonar D2 , Fractal R3, Dell U2312HM
This is supposed to be an excellent case for air cooling but not sure how easy it would be for water cooling.
From another forum:
1.My E6600 overclocked to 3Ghz is running at 27c idle, and 43c under load with Orthos, I'm using Freezer 7 Pro, OCZ paste and P180 case, all fans set to low.
2.mine idle:
core 0: 22c
core 1: 27c
just fans.
and only the ones that came withit. (the top mounted 200mm, rear 120mm, front 2 120mm's)
how ever i moved the rear exhaust to the side panel for now
i am also using the intel stock cooler.
i will admit though, i put a tad bit more than a pea size blob, i put about 2 pea sizes on it of thermal paste on the cpu.
Check out the ThermalTake Mozart Tx. You'll fit your computer bits and water cooling in there, and still have room to park your carjust under the hard drive..![]()
I would say go with the Sharkoon Rebel 9
http://www.sharkoon.com/enghtml/case.htm#rebel9
I just picked one up for £35, and all I can say is ooohhhh my good!
It's got enough room inside it for a good size PC, and has room at the front for a 120mm fan, and room at the rear for a 120mm fan, or 2 80mm fans.
On the side it also has a 250mm fan!!! :O
It's excellent so far, has definitely helped keep my PC cooler, no question about it.
Akasa Eclipse?
http://www.aria.co.uk/Products/Compo...roductId=26784
Hack: i5 2500~ASROCK Z68 EXTREME4 GEN3~8GB Vengance~GTX560~ ANTEC 302~CX600.
Canon 5D Mk3 24-105L / 180mmL / 100-400L / Sigma 35mm f1.4DG / 430EXii
