Preferably want a 512MB DDR3 jobby
Any suggestions?
Any suggestions?
Current Setup
Intel Core 2 Duo E6400 @ 2.2ghz
2GB Elixir PC6400 DDR2 Dual Channel
Asus Gforce 512mb Silent GFX
250GB Seagate SATA HD
http://www.aria.co.uk/Products/Compo...roductId=27199
that'll work a treat, out of stock at the mo. But your not urgent right?
i5 2500k - P8P67 Pro - EVGA GTX 460 SC - 4gb Mushkin + Corsair DDR3 -Coolermaster 650w Gold PSU
looks good, anyone got one?
i wanna get ready to play unreal tournament 3 when its out in September. will probably have to upgrade every component of my pc though haha not just the gfx card 8)
Current Setup
i dont have one, but it WILL work good. Directx10. DDR3. and yeh other stuff in your pc will need upgrading.
Don't waste your money on an 8600gt, if you MUST have dx10 (and theres not much point at the mo tbh) then an 8800gts 320mb is ok upto a point but ideally you want a 8800gts 640mb.
If you don't NEED dx10 then a 1950 is a better option.
