Right well i've fully configured my forums etc & all is going well however i'd like to link my banner to the site homepage..
How would i go about this, i know nothing about php.
Version i'm using is phpbb3
Link To Forums
Link To Forums
Asus Maximus III Extreme | OCZ Obsidion 4gb | Radeon 5770 | i7 860 1156
Haven't used phpbb for years, since v2 or something :L
From what I remember, in the admin control panel, you've got header options (where you've got the image), surely just a html tag would do?
<a href="link" border="0"> existing image code here </a>
Not 100% sure how phpbb still works though, could be thinking of ipb.
Pentium G620T | ASUS P8H61-I | 4GB Patriot 1333Mhz | 64GB Cruical M4 | Antec ISK300-150
Nah i'm pretty sure that is IPB your thinking of.
I think with phpbb, it has to be edited manually in the core php files.
Download our template HERE
Hmm, that is one weird template. Anyway, i think i've got it done but without testing it myself I can't be 100% sure. I have changed one file, I do recommend backing up everything before changing anything.
The header image is not inserted as an image, but rather a background picture which is fine and all, but it was a pain to find. I have changed it now so that it is an image, and i have added a link to it.
Replace the file "overall_header.html" in the directory "1Game\template" with the attached file.
Hope this helps.
http://www.filedropper.com/overallheader
Hmm
uploaded the file & i tested it before doing so & the link works fine, however when you upload it to the main ftp it doesn't seem to want to link anymore.
Did you put it in the styles folder?
Is it still in there?
I've put it in the styles template folder yes & replaced the original file
YOu need to Purge the cache.
It should be in your ACP
lol now i get this
http://www.insomniagaming.co.uk/forums/
Code:Parse error: syntax error, unexpected '}' in /usr/home/insomnia/domains/insomniagaming.co.uk/public_html/forums/cache/tpl_1Game_overall_header.html.php on line 151
Web Dev sorted it & we're in business!
Cheers +Rep
Ahh gawd dangit.
So what had i acidentlly added?
bet ya i hit "}" while putt some enters in. :L
Glad it's all working. See ya over there if I can find something to talk about :L
