Results 1 to 4 of 4
Thread: HiPoint AWR-2440 wireless router
    Jul 2006
    21
    Default HiPoint AWR-2440 wireless router
    http://www.aria.co.uk/Products/Perip...roductId=23552
    The above links to the HiPoint AWR-2440 wireless router, posibly the worlds worst router with the most amount of settings, there is literally hundreds of possible settings. My question to you, more directly to Lucy/Aria staff is who the hell makes these? there is no support website? the company i found was called \"Hi-point elite\" and have 10 staff :? ????
    any help would be great, i am trying to set this up with a bt broadband connection, but with very little look. The installation guide is useless, the only thing that does is gives you basic setup, but alas, that still doesn't work!
    Thanking you in advance,
    Matt
    \"Don't sweat petty things....or pet sweaty things\"
    Jul 2006
    21
    No,i dont think it is. There is no website about for this Hi-Point at all.
    Matt
    Sep 2007
    Hi Matt
    I am sorry you are having problems
    I have a few too port fowarding for one. but at leased it is working??
    I have managed I think to track down the maker??
    Hope this link helps
    Cheers Kevin
    http://www.hipointech.com.tw/
