Right well basically i'm working on a site & i've designed something to show you what i want.
I just want this as a background & have the grey transparent area as the editable bit
Is driving me insane
Asus Maximus III Extreme | OCZ Obsidion 4gb | Radeon 5770 | i7 860 1156
Id be happy to code it for you if u sent me over the background image without the grey bit.
that would go on a seperate layer.
simple thing to do but it may need a bit of editing to the background so it fits in well. since it seems to just stop.
so yeah
PM me or just reply.
HTML || CSS || PHP || MYSQL
Will Code For Cookies
Okay here's the original image
http://img709.imageshack.us/img709/8562/template1t.png
i think he means that the guy would be the background.
and have the grey bit on top as a seperate bit.
just to ask, you did notice that the image has some blacked out text in the middle next to his arm?
ohh and finished.
www.codingogo.net/b/
Valid:
http://validator.w3.org/check?uri=ht...idator%2F1.781
download @
www.codingogo.net/b/dl.zip
i hope thats all good for you.
you should be able to see how to do it if it does need changing tho.
The image needs to be smaller - the quality is reduced by having it that large.
& yes i changed the link for the original image lol
but yeah i think i know how to do it
All is good however the grey box refuses to appear
www.InsomniaGaming.co.uk
thats because it cant find the image.
i had a second image which was grey.png in the images folder.
upload that and edit the css where needed in the box{} bit.
I'll upload an image later what i plan on doing.
The grey box will act as a template where the rest of the site goes.
I'm trying to make something like this
http://www.cynicalbrit.com/
how would you code something like this
http://notquitewhite.co.cc/nqw/
where the background image is static, but the page still scrolls up and down..
-| Intel Core i5 750 @ 4Ghz | 2x4Gb Corsair Vengeance @ 1.6Ghz |-
-| MSI nVidia GTX460 "Cyclone" OC 1024Mb | Logitech X-540 5.1 | Asus Xonar D2X |-
-| Antec 1200 | 2x LG W2286L @ 3360x1050 | 2x 500Gb Samsung F3 RAID0 |-
