Results 1 to 4 of 4
Thread: Monitor help with 8800gtx
    Mar 2007
    Default Monitor help with 8800gtx
    I have a samsung 940BX monitor, and I just built a new gaming computer. When I plug the monitor in, it says to check signal cable...I don't know what to do..
    i have
    e6600
    850 psu
    8800gtx
    everything is powered
    this guy seems to be having the same problem as me, and he found a solution ( read his later post in thread ) but i dont know what hes talking about when he says 2 wires that look alike.
    http://www.lucyslair.co.uk/viewtopic...78e95f0e78cbe6
    please help me!
    110
    If your power supply is modular there will be specially designated PCI-E ports on the power supply, these are normally differently coloured.
    Check your power supply's manual to ensure that you have plugged the modular cables into their correct ports.
    If your power supply is not modular something is faulty - provided that you have plugged everything in correctly.
    Q6600 @ 3.6 GHz | 4GB PC2-6400 | MARS P35
    8800GT (PhysX) | 9800GX2 | X-Fi FATAL1TY
    2x 150GB Raptor (RAID0) | 60GB OCZ V2 SSD
    Antec P182 | 850W OCZ
    Mar 2007
    fixed. thanks.
    83
    9
    Ironic with have the same (similar :roll nick name plus the same problem
