Ok so I got my computer parts from aria after a delay.
I started putting them together, power supply went in fine so did the CPU and the RAM. The motherboard fitted on in the case nicely and this is when I started to get problems.
The first this is wiring my case to the motherboard. The motherboard only seems to have one pin for the each of the case controls BUT my case seems to require two. E.g reset switch, motherboard only have one pin, the case wire seems to take 2.
Second I can't connect up my power supply to my motherboard. The motherboard says it needs a ATX power connector BUT my power supply doesn't seem to have anything that will attach up to it. As i'm new too this it might mean I have the wrong type of power box. I just went with the one that was recommend to me, so I don't really no.
Does this mean I have to get a new case and a new power supply or can I adapt the ones I've got now to save some money. If I do have to buy new things can you suggest any that will work with my motherboard? In the mean time I'm going ahead and installing the CD/DVD drive/graphics card and hard drive.
Thanks in advance.![]()
, Does my \"power switch\" go in to PWRBTN# and the GND next to it?
ops:. Now just to add to the problem it came apart into two things but because they are part of the same wire they won't stretch far enough for them both to be plug in
