Results 1 to 15 of 25
Thread: What Aria will fit in a custom build
    26
    Default What Aria will fit in a custom build
    If I was to get a custom PC from aria, and I mean custom. Would you fit:
    Arctic Freezer64 Pro to an X2 4200+ CPU using arctic silver V?
    Zalman fanless chipset heatsink to an A8N-SLi SE using the same
    the temperature probes on the NZXT Lexa case to specific locations (i.e. Case ambient, CPU and GPU area? (failing CPU, maybe HDD)
    Seems a bit of a tall order but it'd be great if I could have all this done for me.
    Firerat's Avatar
    832
    I don't see why not
    But You would be best off speaking to Tele Sales on 0870 499 2499.
    They can then check with Systems and find out if its all OK,
    They will also be able to add notes to your order to make sure this is carried out.
    But you have got me thinking...
    It might be nice to have a \"comments/Further Requirements\" Text field in the Custom PC section of http://www.aria.co.uk/newAriaSystems.asp
    26
    Hehe, this was posted so long ago I have the PC mentioned now, and am typing on it! It arrived on the 1st July. Not exactly as ordered using a custom comment script, but all the performance related components are right, so i can't moan. Looks fantastic too!
    http://img520.imageshack.us/img520/469/10061614lr.jpg
    Newcastle, England
    153
    man thats wicked
    did it cost any extra?
    Looks really cool.
    Whats the full spec mate?
    26
    X2 4200+ Socket 939 With Zalman CNPS7000Alcu Cooler
    Asus A8N-SLi SE Motherboard
    37GB WD Raptor & 250GB Seagate Barracuda NCQ with Akasa UV S-ATA cables
    Sapphire Radeon X1900XT 512MB
    Hiper Type-R 580W Black
    NZXT Lexa case with Hiper red top-fan
    NEC ND4570 DVDRW, LG DVD-ROM, FDD, Aerocool Coolpanel II
    SoundBlaster Audigy 4 SE
    Dell Ultrasharp 2407FPW 24\" LCD, Viewsonic G90f+/B 19\" CRT
    Thanks for the comments, guys!
    Aria built it for £1250 including Saturday delivery, but with the price drop's we've seen, it should now set you back about £1100.
    m0nk3y
    I know I work here, but the guys who build the systems here are top notch at what they do!
    Because they work with the same cases and mobos again and again, they just build so neatly on auto pilot!
    Damn when I build a PC I'm suprised a bird doesnt fly in and make a nest, but PC Builders here know exactly what their doing!
    I think its something like Parts + £45 to get your PC built by an expert... Well worth it... Nothing quite like putting your new £800 system together and turning it on for the first time to here **BBBEEEEEEEPPP BEEEEEEEEp BEEP BEEP*** ARGH!
    I see websites online who charge like £90 extra just to say they will build your PC 'neatly'.. SCAM *ahem*
    Newcastle, England
    153
    [quote:fa89f0eeaa=\"m0nk3y\"]I know I work here, but the guys who build the systems here are top notch at what they do!
    I think its something like Parts + £35 to get your PC built by an expert... Well worth it... Nothing quite like putting your new £800 system together and turning it on for the first time to here **BBBEEEEEEEPPP BEEEEEEEEp BEEP BEEP*** ARGH!
    I see websites online who charge like £90 extra just to say they will build your PC 'neatly'.. SCAM *ahem*[/quote:fa89f0eeaa]
    aria quoted me £45+vat = £53 today!!!!!!!!!!!!
    and i know some websites online that charge only £10 and £20 and i can send you links via PM if you wish!
    i am reconsidering purchasing now, as £53 is alot of money for a 15min job for a pro
    26
    Yeah quite, I looked through loads of websites, and only Aria and PCSpecialist had remotely what I was looking for, and after PCspecialist would still mean compromise, I went with Aria and I'm quite glad I did. The little things I asked for which they ignored were a bit of a bummer, but nothing I can't rectify myself in a few minutes. I like how they tidied the cables, so they're forgiven, even if they did scam me out of £3. LOL
    m0nk3y
    Scam - harsh words
    Lets me go investigate system build fee
    [quote:278add8cc7=\"DeCrYpT3R\"]
    i am reconsidering purchasing now, as £53 is alot of money for a 15min job for a pro [/quote:278add8cc7]
    LOL i don't consider myself a pro but it takes me a damn site longer than 15 mins to install all the necessary components into a pc and install windows etc then once it's all up and running to tidy all the cables up, your looking at at least a 3-4 hour job to do it \"properly\" not including installing windows its still 2 hours or so.
    26
    I agree with mac124, It takes me a fair while to assemble a system. Maybe not 3 hours, but certainly a good hour, hour and a half, maybe 2 hours with Windows installation (although since I didn't buy that from Aria I didn't have that pre-installed for me). To be absolutely frank, £45+VAT is very little when you consider the charges other sites make. My PC cost me £1250 and the quotes I got from other sites varied from £1550 to £2000, THEY are the scams. This is why I'm prepared to write off being given the wrong type PSU and not being supplied with a chipset heatsink I ordered.
    Ah well you see i like to take my time, check twice fit once type thing :wink:
    26
    Ah so do I. I'm very paranoid about things like that. I spent like a full quarter of an hour installing an X800 Pro I bought back in 2004, which cost £290 at the time!
    Takes me around 30 minutes to do the hardware.
    2 hours to fully setup Windows.
    30 minutes sorting out wires.
    Around 3 hours per PC.
    8)
