Hi guys,
I have just brought a GeForce 7300GT 256MB graphics card, installing it was ok, when i got into the NVIDIA control pannel the tempreture said 55C, is this normal? i have 4 case fans running as well.
Cheers guys
Hi guys,
Cheers guys
* i5 2500K + Corsair H70 * Gigabyte GA-Z68X-UD4-B3 * 8GB Black Dragons DDR3 1600Mhz * Curial M4 128GB SSD * x1 1TB WD Caviar Black 64MB * Asus HD 6950 2GB * Fractal Design Define R3 Black Pearl * XFX 750W Black * logitech Z2300 * Benq G2420HDBL LED 24" - Asus Eee PC Seashell white - HTC Sensation xe with beats audio
Hi,
Yes i would say this is normal as iv only just turned my pc on and my Gainward 8800 is 57C
[quote:33e5aa3dbf=\"ÈL ® ö B ì Ñ\"]Ye but thats a soddin 8800 you lucky git![]()
Have you not overclocked it atall?
I got a 7800GT OC which has been on for 2 days now and it's at 54c....and I have the fan running at something like 30% not 100% and it's overclocked.
But tbh I wouldn't worry about that temp, maybe see what it goes up to when your gaming....i'd say keep it below 65.[/quote:33e5aa3dbf]
Hi,
No iv not tried overclocking anything yet.
My 6800GS idles at about 38/c, with a case temp of around 29/c You have to remember that GPUs can cope with alot higher temps than a CPU.
For instance, the default 'threshold' on mine that is set by the vid card driver is 120/c. So I wouldnt worry too much about 55/c. They get hot!![]()
Yes, I also own a 7300GT (soon to have a second!), and the threshold is pretty damn high. As a general rule of thumb for 6xxx to 7xxx cards, anything up to 80*c is 'safe', believe it or not. If you want the card to last longer though, I'd suggest trying to keep the temp. under 60*c.
My portfolio site: www.rickomann.me.uk
"Your stupid" - my stupid? I don't have a stupid!
I have had this problem before with teh X1600, running at 50 with 100% fan, and 128 and almost burnt itself out ingame, I shoved in a zalman 700cu and it works like a dream, 42 idle, and not a peep over 55 running full with like a 1/4 overclocked cpu, and 1/3 ram.
That sounds normal bigdan, my 7300gt is currently idleing @ 48c and thats with a Zalman cooler strapped to it so mid 50's with stock cooling sounds about right.
my 6600GT is idle at 35c with a threshold of 127c though it did use to be about 42c idle before this case
Main PC: Q6600 / 8 gig DDR2 800 Patriot Dual Channel / Asus P5N-E SLI / EVGA 560Ti DS "Superclocked" / Intel X25-V 40gig / Asus Xonar D2 / Antec 900 Case / BenQ G2222HDL / G15 Keyboard v1 / Windows 7 Ultimate
Desire Owners Club Owner # 13
Just come off playing BF2 with everything on full graphics and my temp is 62C
Which is an ok temp.
My 6800GX idles at 48-49, after thrashing it, it goes up to 65C. Max is set by default at 135C. Never got anywhere near it.Your temps sound normal to me.
[quote:9735aa4983=\"ÈL ® ö B ì Ñ\"]But i ment bigdan:
:wink:[/quote:9735aa4983]
No i havn't Over clocked it, i am think of getting a cooler for it, could anyone recommend a decent one for us?,
Thanks for your input guys
cheers
I have the all copper version of this, unfortunately i can't seem to find it on Arias site but this would do almost as well.
http://www.aria.co.uk/Products/+Zalm...roductId=16701
Or if you want something chunkier then this will do nicely.
http://www.aria.co.uk/Products/+Zalm...roductId=23399
Same i have the full copper, what temps do you get? and what sort of clocks?
[quote:1b962b6690=\"mac124\"]That sounds normal bigdan, my 7300gt is currently idleing @ 48c and thats with a Zalman cooler strapped to it so mid 50's with stock cooling sounds about right.[/quote:1b962b6690]
Not sure what it loads at as im on a different pc atm and clocks are as per media pc in sig :wink:
