Results 1 to 4 of 4
Thread: Wireless Zero Configuration
    Default Wireless Zero Configuration
    Strange problem here:
    ASUS Laptop, inbuilt wireless card.
    When using the ASUS wireless software, the wireless cannot connect to the router.
    When using the Windows Wireless thing it work's like a charm.
    I either need to uninstall the ASUS software, but leave the drivers. (Not sure if thats possible).
    Or set the Windows Wireless to default. And as i dont have wireless installed here i can't remember how to do it.
    Anyone?
    Bournemouth
    191
    I always use windows to configure my wirless networks on laptops it seems to work better.
    There should be a tick box in the properties of your windows wireless bit that says let windows manage your wireless network.
    Tick it
    either that or go start>run and type services.msc
    then scroll down to \"wireless zero configuration\" > right click on it > click start.
    Thats how I do it anyway! I can never find that tick box you mentioned!
    Yeah but this isn't my computer.
    This is some standard user i need to talk through it on the phone.
    Just really looking for the most simple solution i can, which wont cause any problems.
    Ill probably have a look on my laptop later for the wireless box and make sure its clicked, then remove the ASUS wireless software from startup.
    Sound good?
