Results 1 to 9 of 9
Thread: 8 pin power connector for CPU on PSU??
    A Hero Of Many Things Vhero's Avatar
    527
    Default 8 pin power connector for CPU on PSU??
    MY OCZ600SXS has just died on me and I'm pretty sure its not taken my system with it. It has a 3 year warranty and i'm not sure if the warranty is still valid however if its not I will have to get a new PSU for my FP-IN9 SLI motherboard.
    My motherboard manual however asks me for a 24 power connector which is normal and not the problem however my CPU ATX 12v is an 8 pin connector? Do i need a PSU with 8 pins or will a 4 pin be okay? I'm pretty sure I booted it on my old PSU using 4 pin but my memory decieves me i'm not 100% when it comes to PSU's.
    Anyways I also run a 8800GT on this board so whats the cheapest PSU you would recommend anyways?? As I just spent all my cash on new parts and can't really afford a new PSU so this is a problem..
    El Wayneo's Avatar
    Mar 2009
    19,663
    987
    9
    YOu can use just a 4 pin ATX by using it in the closest 4 pins out of the 8 to the socket, but refer to the manual anyway just incase.
    However if you are doing any OCing then 8 is recommended.
    Most decent PSU nowadays will have 8 anyway.
    527
    Quote Originally Posted by El Wayneo View Post
    I figured anyways as I had been using a 4 pin in the past but I really didn't wanna carry on doing that if I was forced to get a new PSU any recommendations for a guy on a budget?
    Trading Post Master Race Terbinator's Avatar
    12,594
    2,007
    Well it also depends on what wattage you need, you could probably get along with a Corsair VX450. If thats too dear then i think all the Enermax PSU's have 8pin connectors however you get less wattage for your money.
    527
    Quote Originally Posted by Terbinator View Post
    Aria dont stock either or anything with an 8 pin under £60
    12,594
    2,007
    Quote Originally Posted by Vhero View Post
    Theres other place ya know - or ask them to price match.
    The VX450 can regularly be found for ~£45.
    Dec 2009
    ExNT
    Dec 2009
    Leicester
    1,521
    31
    527
    Quote Originally Posted by Papa Lazarou View Post
    ACK!!!! You trying to give me a heart attack? read my first post lol thats the same PSU that died one me . NEVER getting and OCZ again.
    Thanks for that shame its out of stock and was a bit dubious about 400w until i read the first comment the guy has alost the exact same spec as mee 8800gt and 3gig with core 2 duo and said it works great so it would defo work in my machine.
