- Rep Power
- 1
turn your firewall off for a moment and try it then u can find that one out
Hazardous
- Rep Power
- 1
Flight Simulator X Captain
- Rep Power
- 2
Hi,
Dont want to use IE7 as with games it ****s them up.
Like Fifa 07, if you have IE7 Dont bother buying it, Fifa07 does not work if you have IE7 installed.
Dont ask why, its just gay.
- Rep Power
- 1
try using ie7 but only for this try and do not make it the default if it asks. Some sites are not compatible with Firefox it depends how it is written.
- Rep Power
- 2
Hi,
But i used firefox with it before on my other pc.
- Rep Power
- 1
Could be a security settings issue, have you check your firefox privacy and security settings are on medium or below so that you are able to use cgi or whatever.
- Rep Power
- 2
Hi,
Did a little google search and found my answer, stupid zoneAlarm Privacy settings was blocking it.
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
