Whats the difference between using a 4 pin ATX and an 8 pin EPS connection to the motherboard and which should I use.
ASUS P5N32E motherboard & S12 600w psu being used.
Never been faced with a choice before lol.
Also Do you conenct both the new sata power conenctors and the old style 4 pin or just the new style as i have a cable and socket fore both.... Confused.
