Results 1 to 15 of 16
Thread: Help me find a graphics card < £60
    Jan 2007
    Newcastle
    Default Help me find a graphics card < £60
    Hello everyone. I'm looking for advice for my new build.
    The build:
    MSI board (onboard VGA)
    AMD 3800+
    2Gb PC3200
    Windows Vista
    blah blah blah.
    So I'm in need of a decent graphics card. I plan to convert this to a media center and connect to my TV using S-video (as my TV aint the best!).
    My criteria is:
    to work well with Vista
    Be fanless
    PCI
    Future proof - (HDTV would be nice!)
    As much memory as possible (unless anyone has a good reason not to?!)
    pretty reasonably priced (hoping to pay no more than £60 if possible)
    I'm pretty clueless on graphics cards - I've always tried to turn a blind eye to them but now I have no option! Pleeeease help
    i looked at this one? http://www.aria.co.uk/EmailAFriendLink.asp?IDNO=24145 any views much appreciated. Is there a remarkable difference in this to the Geforece 6 series?
    If you're going to go for a 7300, make sure it has DDR3 Ram on it - its much faster!
    Jan 2007
    Newcastle
    So DDR3 is the way forward...
    I did see that Gainward card but havnt really heard of the name so kind of overlooked them.. Thanks very much for the suggestions above and I'll be sure to follow your advice.
    Any other views/opinions are welcome.
    Default Re: Help me find a graphics card < £60
    [quote:4b311e8bcb=\"cassa\"]
    My criteria is:
    PCI
    [/quote:4b311e8bcb]
    Please say thats a typing error.
    Guru
    Merseyside
    340
    Default Yep to Gainies
    I would reccomend the gainward, Ive had an old 5200 Gainey play COD 2 BF2 DOOM 3 etc etc.
    Sure its a PCI-E? you need ?
    Mighty... :wink:
    "Some say, that the Pen is Mightier than the sword, but thats just cos they dont have photoshop"
    Mentor Barley's Avatar
    Popovka
    763
    Yeah that's a blinding little card for £70
    Jan 2007
    Newcastle
    wooops, definately PCI-E.
    bigdan676's Avatar
    Dec 2006
    Derby, Derbyshire
    767
    36
    Hi cassa
    why not go for a 7300GT DDR3, Aria don't stock them, but if you look round for one you can buy one for under £60, I can't give you the link but try searching on google,
    Hope this helps
    Cheers
    * i5 2500K + Corsair H70 * Gigabyte GA-Z68X-UD4-B3 * 8GB Black Dragons DDR3 1600Mhz * Curial M4 128GB SSD * x1 1TB WD Caviar Black 64MB * Asus HD 6950 2GB * Fractal Design Define R3 Black Pearl * XFX 750W Black * logitech Z2300 * Benq G2420HDBL LED 24" - Asus Eee PC Seashell white - HTC Sensation xe with beats audio
    Jan 2007
    Newcastle
    Isnt the Gainwood (http://www.aria.co.uk/ProductInfoComm.asp?ID=25130 ) as recommended by PrivatePyle a 7300GT with DDR3??
    I'm :? a bit!
    bigdan676's Avatar
    Dec 2006
    Derby, Derbyshire
    767
    36
    Yea your both right, i have seen the Gainwood but he did say that he didn't want to pay more than £60
    Cheers
    I don't think you will get a 7300gt ddr3 for under £60 but for the extra £10 or so they are leagues ahead of the ddr2 version.
    Also Aria do a 7600gt for under £80 atm
    http://www.aria.co.uk/ProductInfoComm.asp?ID=24384
    Might be worth a look if you are buying now.
    Popovka
    763
    [quote:2a9aad2636=\"PrivatePyle@Work\"]http://www.aria.co.uk/ProductInfoComm.asp?ID=25130
    This is the card for you. It is £70 so I'm £10 over budget, but the performance difference with Vista will be worth double that (more actually..)
    The card you chose has DDR2 video memory on board, the one above has DDR3. Its a brilliant little card for a media centre, you could even get away with some gaming with it so long as you keep respectable resolutions and settings.[/quote:2a9aad2636]
    I'd also like to point out that I've come to the conclusion that PP actually gets commission for recomminding those cards or something
    I have recommended them on a few occasions too, i may have been the first one to recommend them actually??. I do actually own one and it IS a blinder of a card for the £££. Would recommend them to anyone whos building a pc on a buget but wants some gaming ability.
