Results 1 to 4 of 4
Thread: Custom Build
    Jan 2007
    Llanelli
    Default Custom Build
    Hi
    I used the Custom Build part of the site and saved the result.
    How do I retrieve that build now, a day later/
    Also the parts I want are to fit and existing case, psu HD's etc so does not constitute a build. Do I have to pay the £45 build fee?
    regards
    Des
    You would buy the componants seporately through the main part of the store, as teh custom builder is for whole pcs customly made.
    110
    I'm confused.
    Do you want us to build this for you? or are you just buying the extra components and then putting it together yourself?
    If it's the latter, just buy them through the normal website.
    If it's the first, speak to our telesales team who will be able to advise you further
    Q6600 @ 3.6 GHz | 4GB PC2-6400 | MARS P35
    8800GT (PhysX) | 9800GX2 | X-Fi FATAL1TY
    2x 150GB Raptor (RAID0) | 60GB OCZ V2 SSD
    Antec P182 | 850W OCZ
    Forum Addict
    260
    To view your saved system, bring up the customer pc builder, click on \"View Aria Systems\", scroll right down to the bottom and conveniently hidden at the bottom will be your saved build (if logged in).
    Chris.
    The Server is Down! Quick! I need a roll of duct tape, 3 wads of chewed gum, a paperclip and a plastic fork!
