Results 1 to 9 of 9
Thread: Battlefield 1 Stuttering Issue
    Makai_Neko's Avatar
    Sep 2009
    114
    Default Battlefield 1 Stuttering Issue
    Hey guys, i'm having problems running BF1 on Conquest mode, Team Deathmatch works fine since its a smaller map.
    On Ultra @ 900p im getting 35-55 fps, but there is a stuttering issues when loading up textures and explosions ect on big maps.
    After looking on youtube of machines running BF1 flawlessly on weaker machines, made me curious if there is a fix for this issue.
    Specs are on this machine:
    Phenom II x6 1100t @ 3.8 Ghz
    16GB DDR3
    GTX 1060
    GA-78LMT-USB3 Mobo
    Main Rig: Corsair Spec 03 Case, Gigabyte B150M-D3H, Intel 6600k CPU, 16GB 2133Mhx Ram, GTX 1070 4gb, Kingston 128gb SSD, 1TB Samsung HDD, Windows 10
    Old School HTPC Rig
    : AMD Athlon 64 4400x2 @ 2.5Ghz, 939A785GMH/128M, 4gb Ram, 128gb SSD, 160gb HDD, Win 7
    Mid Ranged Gaming Rig: Phenom II x6 1055T, GA-M720-US3, 8GB Ram, GTX 1060, 128GB SSD, 1TB HDD, Windows 7
    Dipsomaniac BUDFORCE's Avatar
    Oct 2011
    Cambridgeshire Fens
    3,343
    317
    That doesn't sound right.
    Admittedly my GPU is one up (1070) but I'm running it a max settings 1440p at 60 FPS.
    My CPU is an older Sandybridge i7 2600k.
    At 900p doesn't sound like something you graphics card should be struggling with, sounds more like CPU or memory.
    Although wait, do you have one of those 3gb 1060's?
    If you really really really really love me. You'd never make me hang out with your family. Your mum sucks and your dad really hates me. When I try to borrow money he berates me. Somehow he thinks that I'm too old for you, 'cause you're nineteen and I'm fifty two.
    Makai_Neko's Avatar
    Sep 2009
    114
    Yeah its a 3gb 1060, so my graphics card is the issue? xD
    Old School HTPC Rig
    Oct 2011
    Cambridgeshire Fens
    3,343
    317
    Quote Originally Posted by Makai_Neko View Post
    Honestly I don't know, it could be a whole load of reasons. If you can fire up some kind of gpu monitoring software, like Evga precision X for example, it'll show you your gpu memory use in game and see if it's hitting the limit in game, but at 900p I'd be surprised but I don't know how VRAM hungry BF1 is.
    I'd be leaning more towards you CPU though, as when you have a bigger maps, more objects, more things to process, and sudden sharp short FPS losses tend to be more CPU related.
    You could also have a virus on your pc, or other random software issue causing it.
    Sorry probably just given you more doubts then help here, to d try downloading some gpu/CPU monitoring software to see if it's hitting any of those when it happens.
    Finners's Avatar
    Portsmouth
    4,827
    253
    BF1 is such a well optimised game I'm surprised your having problems even on your older CPU because it has so many threads however I think that where you issue must be.
    What are you temperatures like? Your 1060 is more than powerful enough so im wondering if your CPU is throttling down due to high temps.
    try leaving a program like HWmonitor running in the background and see what your CPU core max temperatures are after a gaming session.
    i7 2600K @ 4.5| Asrock Z68 Extreme4| 16GB 1866Mhz Crucial Ballistix |AMD R9 290| 120GB SSD |Win7 64bit
    Makai_Neko's Avatar
    Sep 2009
    114
    Yeah maybe, but after watching this video:
    I have my doubts that a cpu bottleneck is the case, since in this video, that 1090T is bottlenecking a 1070 by only 20-30%.
    Im gonna try installing BF1 on another Harddrive and see if that makes any difference, is usually lags and stuttered when the program is accessing my harddrive (When the HDD Light goes off).
    Other games like GTA 5 have similar issues, buts its nowhere near as bad as it is in BF1 and has playable fps (40-60) on very high.
    CPU Temps are fine, 55-60 Degrees, but i am gonna get another cooler and test my motherboards ability to OC.. Its currently OC'd to 200 FSB x 19 multiplier (Since my CPU is a Black edition)
    Old School HTPC Rig
    TAZ007's Avatar
    Nov 2011
    S.Wales
    2,278
    324
    Are you using an HDD or SSD?
    Oct 2011
    Cambridgeshire Fens
    3,343
    317
    Quote Originally Posted by TAZ007 View Post
    Yeah but I have BF1 installed on my mechanical drive it runs fine.
    Moderator
    25,364
    7,329
    i would see if over/underclocking the cpu makes the issues better or worse.
    but i also imagine the cpu is more likely to be the cause of stuttering like this
    that gpu should be great for 1080 gaming. at those low res it is mostly a cpu test as the gpu are waiting on it, not being stressed to its max.
    "Those able to see beyond the shadows and lies of their culture will never be understood, let alone believed, by the masses."
    Plato
