Thread: PHP/Coding Help
    Boob Inspector M4T VW's Avatar
    Aug 2007
    Bristol
    9,475
    496
    9
    Default PHP/Coding Help
    Trying to write a small wordpress plugin to take the username from xenforo session cookie and display it on the wrodpress site using a shortcode. I'm very close but my lack of PHP has hit me. This is my current code:
    PHP Code:
    include_once( plugin_dir_path( __FILE__ ) . '/includes/xf_connector.php' );
    $xf_userId = $visitor['user_id'];
    $xf_username = $visitor['username'];
    function xenfield_shortcode() {
      ob_start(); ?>
      <div class="xenfield">
        <p>echo $xf_username;<p>
      </div>
      <?php    return ob_get_clean();
    add_shortcode'xenfield''xenfield_shortcode' );
    That currently returns just "echo $xf_username;" in plain text and not the value. I cannot seem to get it to display the value for some reason.
    The following code works on a blank page so i know if sort of works.
    PHP Code:
    <p>Hello <?php $xf_userId $visitor['user_id'];
    $xf_username $visitor['username'];
    echo
    "$xf_username?> welcome to this web page.</p>
    Any help?
    Mat
    Quote Originally Posted by Aria View Post
    On reflection though, as I am taking a bath, listening to "Rain of blessing-vajra chant" while typing on the iPad
    🙈 🙉 🙊 heavywater's Avatar
    7,117
    768
    9
    Just wrap the echo in php tags, it's currently outside your blocks so gets treated as HTML.
    EDIT- assuming that's not the whole code obviously as you'd need opening/closing tags on the rest.
  3. The Following User Says Thank You to heavywater For This Useful Post:
  4. #3
    Aug 2007
    Bristol
    9,475
    496
    9
    Like this?
    PHP Code:
      ob_start(); ?>
    echo
    "$xf_username?>
      </div>
    This actually returns nothing
  5. #4
    7,117
    768
    9
    Sorry, not very clear. You'd just need to wrap the php in tags. You could echo the html as well but in this case it's not really necessary.
    So for your above extract your HTML section should just be:
    PHP Code:
      <p><?php echo $xf_username?><p>
    </div>
  6. The Following User Says Thank You to heavywater For This Useful Post:
  7. #5
    Aug 2007
    Bristol
    9,475
    496
    9
    Sadly not, That also displays nothing. Looking at the HTML it shows empty <p> </p> tags
  8. #6
    Rocketeer Toonshorty's Avatar
    Mar 2010
    Newcastle upon Tyne
    7,041
    152
    Try hard-coding the variable, that would at least confirm whether the problem is with the output. It could just be that $visitor['username'] is actually just an empty string?
  9. #7
    Military Grade Tester DoubleTop's Avatar
    Nov 2009
    In a lamp
    12,773
    134
    PHP Code:
      global $visitor;
      ob_start();
    <?php
        $xf_userId
        echo
    $xf_username;
      </div>
    <?php
    You might not need the global, and you can shorten the declarations a bit if you wanted to
    PHP Code:
      ob_start();
    <?php echo $visitor['username']; ?>
      </div>
    <?php
    You have a bit of a combo of errors, things enclosed in "" are a string, yet you seem to want to output the variable content, along with a missing ; which will cause a syntax error and be logged somewhere depending on the server setup.
    A little bit of guesswork though without having the entire xf_connector code or any idea how that is formatted.
    DT.
    Please see thread, here for how post reports are dealt with.
    Forum Guidelines here
  10. #8
    Aug 2007
    Bristol
    9,475
    496
    9
    Thanks guys, managed to get it working and will post the code tonight. Someone wrote it for me and it looks completely different to how i expected it
