Results 1 to 5 of 5
Thread: Upgrade my mac
    May 2008
    53
    Default Upgrade my mac
    I want to upgrade my mac (white macbook from about march this year) because it only has 120GB HD space and I have that in movies and music alone, and I was just wondering what hard drives are compatible for my mac.
    I was looking to upgrade to 500GB, and also I have 2GB of RAM but unfortunately I think apple have given me 2x1GB sticks, therefore I was also wondering what RAM options should I choose to upgrade, I think 3GB will do me for now with the option to get another in there later on when I feel I need it.
    The reason for the extra RAM is I want to dual-boot windows on my laptop for the sake of uni work (I'm doing computer science), and at the moment with my tiny amount of hard drive space left my mac is quite slow anyway, let alone dual-booting.
    Cheers.
    Military Grade Tester DoubleTop's Avatar
    Nov 2009
    In a lamp
    9,878
    117
    I took apart my iMac 20" Intel last week, you'll need a small set of torx screwdrivers to start with and a fair amount of patience.
    The 120Gb drive that was in mine was a bog standard 3.5" sata drive, the only thing to watch for is the temp sensor that is attached on the side.
    Ram wise, I think the Mac board (depending on your exact model) will only take 3Gb max, it uses laptop ram and can be found dirt cheap.
    To be more accurate, more info than just a white iMac would help
    DT.
    Quote Originally Posted by Aaron View Post
    By the way DT - what happened to the initiation process of them being pink for a few weeks?
    May 2008
    53
    http://www.aria.co.uk/Products/Compo...roductId=37761
    is this one compatible?
    it's cheap and the size im looking for
    Also does anyone know if the HD my macbook uses would be possible to put in my PS3?
    cheers
    Nov 2009
    In a lamp
    9,878
    117
    don't know on the ps3 front, what does that use?
    the macbooks all use a standard 2.5" sata drive so I'm told, so that's an easy upgrade route. For laptops, I cannot recommend highly enough getting a faster RPM drive, sacrifice the battery life but it makes them so much quicker. As you say though, that's a nice price
    DT.
    Quote Originally Posted by Vyper08 View Post
    cheers
    There was a whole thread here last night! I had at least 3 replies in this topic. As long as the Hard Drive is a 2.5" SATA drive, then It'll be fine in the PS3.
