I am building a PC using the spec from Rick maybury's Boot Camp. I have a problem with the System panel header wiring. The case (Generic Black/Sil Midi Tower) has various cables which should be connected to the motherboard (ASRock 775i945GZ). However I cannot identify from the labelling on the cables which pins they should go to on the montherboard.
1. How do I identify the polarity?
2. Are the two cables (yellow and white) labelled \"Standby\", with a double plug, the same as PLED ?
3. What are the two (blue and white) intertwined cables - not labelled - with single plugs?
Can anyone help please?
yeah thought so, in this case white
