Results 1 to 3 of 3
Thread: Radeon X1600 Pro Product Code :GCX-PC-R53B-PE3
    Oct 2006
    london
    Default Radeon X1600 Pro Product Code :GCX-PC-R53B-PE3
    I got the above 2 months ago, if i needed to buy another card to enable the crossfire, Please advise if i have to buy another same card , set one up as master and the others as slave. and where do i get the cable from ?
    Great Card though, graphic are ace on World of Warcraft and Tomb Raider legend
    You need a master card with Crossfire as far as I remember, have you got a crossfire master card X1600? Also buy the same spec card, because the master is the speed that the slave will go at, so there is simultaneous graphics rendering, but remember, two cards dont mean twice performance, if it works out better price, then sell the X1600 and use the money along with the budget for the new X1600 and get a good card with that.
    Isn't worth the aggro mate, sell it and get a better single card, 1800 / 1900. There really is very little point on doubling up on mid range cards.
