Hi everyone,
don't know if you remember me (http://www.aria.co.uk/lucy/viewtopic...142&highlight=)
but i'm in need of some more advice.
My dad has just asked me recently to give the home pc a little upgrade preferably for no more than £200.
The current pc spec. is pretty outdated. The processor is a 2.6Ghz intel celeron r which i suppose is not too bad. I'm almost certain that the low memory total is the key factor which is holding the pc back. Only 256 mb of ram is installed.
I've had a little look around and have spotted these (i've included a cpu just to see whether it is a good upgrade or not) :
Intel Pentium D 915 Dual Core RET
[CPU-I-P4-915R]
http://www.aria.co.uk/ProductInfoComm.asp?ID=23907
1GB PC5300 Elixir DDR2
http://www.aria.co.uk/ProductInfoComm.asp?ID=22118
Asrock CONROE945G-DVI Socket 775
http://www.aria.co.uk/ProductInfoComm.asp?ID=25680
At first glance they look suitable but i'm unsure on whether this is the best option for the budget.
Thanks in advance guys, i know you'll come up with the goods!
