Results 1 to 6 of 6
Thread: Graphics card for twin monitor set-up
    Dec 2006
    Accrington
    Default Graphics card for twin monitor set-up
    I am looking for a AGP graphics card that will run two monitors, but I am having trouble locating one with 2 D-sub outputs.
    I want to work with CAD/CAM on one screen and a text editor in the other so it is not just a case seeing the same on both.
    Any suggestions or advice would be appreciated.
    110
    If you get one with a DVI and VGA output just grab one of these.
    http://www.aria.co.uk/ProductInfoComm.asp?ID=7022
    Takes a DVI output and gives you VGA back
    Q6600 @ 3.6 GHz | 4GB PC2-6400 | MARS P35
    8800GT (PhysX) | 9800GX2 | X-Fi FATAL1TY
    2x 150GB Raptor (RAID0) | 60GB OCZ V2 SSD
    Antec P182 | 850W OCZ
    Yeah any gfx card with 2 monitor connectors should do the job and most, if not all, will come with the necessary adapters to plug a dvi output into a vga monitor all the ones i have bought did anyway.
    110
    [quote:a156f995a9=\"mac124\"]Yeah any gfx card with 2 monitor connectors should do the job and most, if not all, will come with the necessary adapters to plug a dvi output into a vga monitor all the ones i have bought did anyway.[/quote:a156f995a9]
    Depends how much you spend, but yeah; some will, some won't.
    Dec 2006
    Accrington
    [quote:20d35f7ad9=\"Sean\"]If you get one with a DVI and VGA output just grab one of these.
    Takes a DVI output and gives you VGA back [/quote:20d35f7ad9]
    I already have a Radeon 9000 Series card with both a VGA & DVI output so one of these neat little gizmos should do the trick.
    Thanks for the tip!
    Dec 2006
    Accrington
    Default Success!
    Thanks to Sean for the adaptor tip, it works a treat, and contrary to what \"blaineoliver\" says in the thread :-
    http://www.aria.co.uk/lucy/viewtopic.php?t=1214
    You can use XP Home as I'm typing in TextPad on the RHS while viewing FireFox on the left.
    This is going to make buiding web pages so much easier!
