Would you buy...
Lian-Li PC-6070 PLUS Silver Aluminium Midi-tower No PSU
HiperPower 525W HPU-4S525 4th Gen PSU Quiet Triple Fan (Active Fan Control) aPFC 23dB
NEC ND-7170A-0S Silver x18 DVD±RW Dual Layer (with Ram Support ) DVD-Writer OEM UK
Sony Silver 16x DVD-ROM + 48x CD-ROM IDE (oem)
Akasa Allinone 5.25\", 21 function panel, Multi memory card reader, Multi port access, Manual/Auto smart fan control (Silver)
74GB Western Digital Raptor, SATA, 10000 rpm, 16MB Cache
320GB Seagate ST3320620AS Barracuda 7200.10, SATA2, 7200 rpm, 16MB Cache, , NCQ
All the above as standard, fitted with either
The AMD Option ---------------------------------
AMD Athlon 64 X2 5200+ Windsor 2.6GHz 2 x 1MB L2 Cache Socket AM2 Dual Core Processor - Retail Box
Sapphire ATI Radeon X1950XT, 256MB PCI-E(x16), Mem 1800MHz GDDR3, GPU 625MHz, 48Pipes, VIVO
Corsair® 2Gb (2X1Gb) CorsairTwinX XMS2 Dominator, DDR2 PC6400C4, 240 Pins, Non-ECC Unbuffered, CAS 3-4-3-9, EPP
Asus M2N32-SLi-DLX nForce 590 SLi (Socket AM2) PCI-Express DDR2 Motherboard with WI/FI
OR
The Intel Option ---------------------------------
Intel Core 2 Duo E6600 S775, 2.40Ghz, 1066Mhz FSB, Conroe Core, 4M Cache Retail
Asus P5N32-SLI SE Deluxe 1066 / 800 / 533MHz, DDR2, SATA, Dual Gigabit LAN, 8-channel SND Core™2 Duo Ready
Asus GeForce 512MB 7950GX2, PCI-E (x16), Standard, Mem 1200 MHz, GPU 500 MHz, 48 Pipes, S-Video/2xDVI
Corsair® 2GB DDR2 XMS2 Dominator PC2-8500C5 TwinX (2x1GB)
Its gotta be intel right?
