I Have a usb wireless adaptor and vista upgrade advisor said it may not work, so I put on the RC2 trial and sure enough, its not working.
Anyone know what a good wireless adaptor that will work with vista is?
Ideally 108mbps and usb.
Thanks.
Thanks.
We have around 3 different 3COM wireless adapters here and each one works fine with Vista.
8)
I can't find any 3Com wireless adapters. Can you suggest any others that will work with Xp Pro x64 and vista?
Cheers.
Here is a list of Netgear supported Wireless adapters:
http://kbserver.netgear.com/kb_web_f...irelessadapter
PCI Wireless Card, Vista Supported.
http://www.aria.co.uk/ProductInfoComm.asp?ID=23661
Aria currently have no USB Wireless Adapter's in stock that support Vista.
I can't go linking around to other sites, so i recommend either waiting for Aria to get one of the supported Netgear adapters in stock or buy from another site.
:wink:
Thanks for the advice.
