Thread: Hardware upgrade and questions about some products
    28
    Default Hardware upgrade and questions about some products
    Hi all. Following my recent motherboard and processor failure (bought before knowing Aria at major but not reccomended PC chain) I need to exchange those devices. It would be the best to stay in budget of maximum 200 quid, however with the products I've written below is bit more I think
    So I was thinking mainboard: Asrock CONROEXFIRE-eSATA2 775 or Gigabyte 8I945PLGE-RH Socket 775. However I am not completely sure whether those new DDR2 slots will take my older 1x512MB and 1x256MB DDR PC3200 400Mhz. I also have HDD with older Serial Ata I (both motherboards have II).
    This is obviously for Pentium D 820 - I think good price and quality with advantage of Dual Core!
    Because my old graphics is a bit old and x8 AGP so would suit PCI-E x16 of Geforce 7300GT or 7600GS. They need to have 256MB and be 128bit. I found in Super Specials: nVidia Geforce7600GT 128bit and 256Mb DDR3 for 70 quid!, but I do not think it is wholly nVidia product as they rather only do processors for graphics. Anyway the price for it should be around 100, so is there a problem with it or is it such a good offer? If not this than maybe Gainward or Inno 3D?
    And I will also need better PSU (old 300 or 350W). Around 450-600W should be enough (1HDD, 3xPCI, 2xsystem fans, maybe I'll take one more) but still would prefer cheaper but good quality as well
    When I change all of those components than I will fully have Aria only products PC (except old case).
    Thanks in advance for responds.
    27
    I have had a lot of problems with cheap and low power PSUs I would always recommend going for the best and more than 500W. I had a problem that whenever I tried to burn a DVD the computer would reset and it turned out to be a PSU near its limit on one of its lines. I put in a 600W one and have had no more problems
    john
    27
    I agree I didn't have problems to start with but I think it degraded over time and of course I had added another dvd writer another hdd or 2 and USB devices?? So what did I expect really.
    28
    Thanks a lot for advice! Especially for that with DDR2, I did not know that. So I think I am finally getting to order:
    - Intel Pentium D 820 Dual Core - 70 punds;
    - Gigabyte 8I945PLGE-RH Socket 775 or Asrock CONROEXFIRE-eSATA, still not sure which - 57;
    - Gainward Bliss 7300GT - 70;
    - 600W Super Silent ATX Power Supply - 17 - I would prever Xilence 420W for 30 quid but might be not enough power, and this higher price;
    All of this with my 3xPCI cards, 2xfans(+1?), 2xDVDRW/CDRW, 1xHDD (sometimes 2nd as well), few USB devices.
    Any idea is this all compatible and that graphic card will get inside (req 2 slots?). Oh and that DDR3, would you recommend any, can I buy only one or it needs to be two? But please keep in mind that I am already over budget (214)
    Thanks a lot.
    [quote:f4a564d833=\"marwyso\"]
    - 600W Super Silent ATX Power Supply - 17 - I would prever Xilence 420W for 30 quid but might be not enough power, and this higher price[/quote:f4a564d833]
    Be warned cheap psu's are cheap for a reason, the 430watt Xilence maywell have extra saftey features or the \"cheap\" psu might be quoting MAX power not continuous power. You arent building a mega powerful system so i would go for the lower power more expensive branded psu rather than some cheapo generic pap.
