Results 1 to 7 of 7
Thread: BT home hub help
    Default BT home hub help
    I have that BT home hub, but its signal for wireless seems to be pretty weak.
    SO pretty simple question for you all I reckon, but I just wanted a bit of help...
    Can I plug a wireless router into the RJ45 ethernet slot that I would use for a wired connection, and just use that for wireless?
    If so what wireless router is best? 108mps ideally.
    Thanks very much for your help
    Mickey mouse ears mate, thats what you need.
    Mickey Mouse ears
    I would say that thers no problem, but dont know for sure, at my house there are 4 routers before i get signal,ntl, main wireless, 30port switch, personal hub. And have no confilicts.
    Aug 2007
    the hub has two rj45 ports so could work but wireless is still a lot slower than hardwired through the rj45 port I get 500 to 600 kps downloads
    but wireless is to SLOW...
    Also you could check here :
    http://www.radioandtelly.co.uk/cgi-b...board=btvision
    this forum is for bt vision and bt hub !!
    Veteran
    Jun 2007
    Cambridge
    137
    dude this thread is from like nov 06...
    Veteran
    Wales
    151
    dude, this forum is like, slow
