Results 1 to 9 of 9
Thread: Monitor Advice
    Inaban Toonshorty's Avatar
    Mar 2010
    Wylam, Northumberland
    6,376
    135
    Default Monitor Advice
    I'm thinking about replacing my Dell P2210H.
    It's a great monitor but the number of inputs is a little restrictive for me.
    The problem lies in that I'm both a gamer and graphic designer and therefore colours but also responsiveness is important.
    I'm looking for a monitor (Preferably under £200) that has good colours and decent response times (Not too worried about this, just so long as it doesn't have noticeable lag/ghosting). IPS is also preferred.
    Since there are a silly number of monitors around at the minute does anyone know of any solid choices at present?
    Mr idea-Gamez theste's Avatar
    Feb 2011
    Swinton
    1,010
    313
    hi mate it seem you are looking for a dell ultrasharp monitor (true me there are good for colour , if set-up right). yess they do have a high response time, but that does not make that much differences for gaming at all.
    The price do vary to the size, but you can get a 23" for less than £200 .
    i also do a lot of gaming, graphics, web design etc using a dell ultrasharp monitor and it is great.
    Steam ID - theste1234
    Intel I5 2500K | MSI GD65 | 16GB Mushkin Blackline | Asus GeForce GTX 560Ti DirectCU II | Corsair A70 (1X Noctua NF-P12) | Crucial M4 120GB | 1TB Samsung SpinPoint F3 | Corsair TX 650W PSU | Fractal Design R4 Black Pearl | Windows 8 Pro 64bit
    Avoid XFX!!! Terbinator's Avatar
    13,063
    2,053
    U2312H?
    Survives the Apocalypse Broadsword1976's Avatar
    Feb 2008
    Torquay
    3,805
    934
    All I can say is; if you can stick with Dell - you'll be slightly, very slightly perhaps, disappointed by anything less having already owned one (at least that's how I feel).
    Gigabyte 880GMA-UD2H.AMD 1055T @3.5Ghz. 8Gb Mushkin Redline, MSI 6850OC, 60Gb Mushkin Chronos + 256Gb Crucial M4 + 2x2Tb F3 Spinpoint Eco-Greens + 1x 1Tb Spinpoint F3. Antec 900 Watt PSU . Windows 7 64 Ultimate
    Desire Owners Club Owner #7
    Hnnnnnnnnnng! Naphta's Avatar
    May 2010
    Kidderminster, Worcestershire
    4,494
    175
    Eizo are the best
    Dell are the best if your poor.
    I type 90 WPM, Click Here to try
    i7 3770k @ 4.6ghz | Gigabyte Z77X-UD5H | GTX 570 | 16GB Ram @ 1600mhz
    Nikon D5100 + Kit Lens + 50mm 1.8G // Ultrasone PRO 2900s - Audio GD NFB-3.1 - Neco Mosfett Amp
    Gunslinger's Avatar
    Mar 2010
    Oxfordshire
    3,721
    394
    LOL @ Naphta, interesting comment, but fairly accurate, for the average man, some of the top end Dell screens are more than good enough, to be fair, i am happy with the 2 i have, i have also seen a good Eizo screen in use, as well as some professional NEC models, and they are very very good, but for the cost outlay, not sure if they are worth it !
    one thing i would like to see more of, is true PC monitor ratio of 16:10 i am fed up with seeing 16:9 "Monitors" ..... that is NOT a native monitor ratio, that's a dam TV ratio ! you lose a surprisingly noticeable chunk of screen real-estate
    What i find with Eizo monitors, is that the range is not updated all that often, sometimes a good thing, sometimes bad...... for example....
    EIZO Foris FS2431, current model, reviewed here......
    http://www.pcpro.co.uk/reviews/monit...o-foris-fx2431
    .... in 2009
    Dell XPS L702x | i7-2860QM | Nvidia 3D 3GB 555m | 32GB Corsair Vengeance | HD 1080p 3D Display | Mushkin Chronos Deluxe 120GB SSD | Seagate MomentusXT 750GB Hybrid Drive | Blu-Ray/DVD/CD Burner | Advanced-N 6230 Wi-Fi + Bluetooth | TV Tuner | Backlit KB | 9-cell Battery | Win7 Ultimate 64bit (non Dell install)
    May 2010
    4,494
    175
    Quote Originally Posted by Gunslinger View Post
    .... in 2009
    when 4k goes mainstream I'll probably jump on an eizo oled. (when the price is sub £1500)
    IsaacKingsley's Avatar
    Nov 2011
    Levenshulme
    178
    23
    I have 3 of these
    No competitor links please
    Intel i7-2600K @ 4.6 GHz - Asus P8Z68-V Pro /Gen3 - EVGA GTX 680 SC 2GB - 8GB Exceleram White Sark DDR3 - OCZ Solid3 120GB SSD - 850w Corsair HX - 2TB Storage - XSPC RX240 radiator - XSPC RX120 Radiator - Corsair 800D
    My build: http://forums.aria.co.uk/showthread....)-56k-Warning!
    May 2012
    122
    Dell Ultrasharp are often considered some of the best you can get for a reasonable price.
