Results 1 to 3 of 3
Thread: MSI Z77A-GD45 Front USB
    MixtaMike's Avatar
    Apr 2012
    Norfolk
    635
    55
    Default MSI Z77A-GD45 Front USB
    I cant seem to get front USB 3 to plug in , it could be that there isnt enough room as i have a Corsair Carbide 500r.
    The board kinda sits in a recess. Hard to push it in.
    The Cable is thick so its hard to manipulate, either way I cant seem to plug it in, I feel if I use anymore force I would damage it
    Any suggestions?
    Supermoose's Avatar
    May 2011
    Leeds
    946
    28
    You can buy USB extension cables there about £2 and made by arkasa. I had to get them for my itx case lol.
    Intel i5 4670k | MSI Z87-G45 Gaming | G-skill Sniper 1600mhz 8gb@ 1.25v | EVGA ​670 | Crucial M4 128gb | Noctua NH-D14| Silverstone Raven 2| Corsair tx 650w
    MixtaMike's Avatar
    Apr 2012
    Norfolk
    635
    55
    Ok ill give that a go
    Edit:
    Im talking about the 20 pin header , is there an extension which is at angle similar to what you can get for a sata cable?
    I was supplied with an adapter but it seems to convert usb 3 to a regular usb adapter ( 20 pin to 6/8pin?) to plug into the mobo
