Results 1 to 3 of 3
Thread: would this system work?
    22
    Default would this system work?
    would this be a good system and would it work?
    AMD Athlon64 3800 Venice Retail
    Socket 939
    Foxconn 6150K8MA-8EKRS Socket 939
    ONBOARD 6150 GFX / PCI-E x16 / TV OUT / Gb LAN / DUAL CH DDR / SATA RAID / mATX MOTHERBOARD
    Crucial 1GB DDR2 PC4200 240-PIN
    CT12864AA53E
    250GB Maxtor D/Max+21 133/7200
    What do you want this system for? And there is a clash, DDR2 doesnt work with DDR, you would be far better off with AM2, completely future proff, let me show u an example:
    CT12864AA53E
    ASUS M2NPV-VM nF430 Socket AM2
    AMD Athlon 64 3200+ Retail AM2
    250Gb Samsung / 7200 / 8 IDE HD250KD (dont go for maxtor)
    That is along the lines you seem to be thinking, but if you say a budget then we can show you the best choice.
    I know, that confused me.
