Results 1 to 5 of 5
Thread: Quick Help! OC failure :-/
    karlChev's Avatar
    May 2012
    Manchester, Gorton (Don't be put off)
    152
    Exclamation Quick Help! OC failure :-/
    Was running my Ivy i7 3770k at 4.40ghz for some time now, decided to have a play around this morning as i woke up strangely early. OC'ed to 4.60ghz and was idling at 40c with my h100, so i decided to push it to 4.80 to see what i could get from it. I saved and rebooted, now i get a black screen and in the top left corner a _ sign, and botton right it says A2 in white :-/ Wtf? Ive had it at 4.8 before and it ran fine. I also tested my SSD boot drive in another pc and it booted fine, so thats all good.
    Im running a
    i7 3770k on a
    Z77 MSI GD43 Mobo (Clocked at 4.80GHz, but like i said...wont boot, properly)
    H100
    AMD 7970 @ 1Ghz
    8g corsair vengence
    750PSU
    chronos 120G SSD
    1TB Caviar Black
    Help
    Devil's Advocate marsey99's Avatar
    St Helens
    18,335
    2,701
    unplug, hit the power button a couple of times to remove any power and hit the clear cmos button the back, then start again
    we know who we are,
    most successful english football team ever, liverpool fc.
    we know who we are.
    karlChev's Avatar
    May 2012
    152
    And where is the magic clear CMOS button? Thanks btw !
    St Helens
    18,335
    2,701
    ah, gd43, no button, you need to jump the 2 pins next to the bat on the board.
    we know who we are,
    we know who we are.
  5. The Following User Says Thank You to marsey99 For This Useful Post:
  6. #5
    karlChev's Avatar
    May 2012
    152
    Took the battery out in the end=p Thanks!
  7. The Following User Says Thank You to karlChev For This Useful Post:
