Thread: need help with a build
    22
    Default need help with a build
    I want to build my own pc but dont know alot about it.
    Basicly i want it to have;
    3500+ cpu
    1 gig of ram
    and around 250 gig hardrive
    I mainly use my pc atm for photoshoping and downloading
    cheers ben
    22
    Well i plan to start a graphics course next year so i will be working with quite big image files on photoshop. I want to spend around 350 pounds not including the screen. I dont know about Intel or AMD as i dont know alot about pc's but i have had AMD in the past.
    22
    i wouldnt play games on it
    22
    the course i will be doing is just a founation course where i will be mostly using photoshop for images and not so much animation, will i need a gcard if i will never play games on it
    22
    i would also need a case and hardrive
    22
    what i would do is buy 1 gig of ram and then but buy another at a later date
    22
    would this be a good system and would it work?
    AMD Athlon64 3800 Venice Retail
    Socket 939
    Foxconn 6150K8MA-8EKRS Socket 939
    ONBOARD 6150 GFX / PCI-E x16 / TV OUT / Gb LAN / DUAL CH DDR / SATA RAID / mATX MOTHERBOARD
    Crucial 1GB DDR2 PC4200 240-PIN
    CT12864AA53E
    250GB Maxtor D/Max+21 133/7200
