Once my coding is all sorted out, I'll be changing my graphics to JPEGs and GIFs, but for now, I'm using the "beta" PNG images, so don't worry about that.
Here's the bit I'm having trouble with: I have a div which contains a table. Each cell of the table contains a single link. I want a simple CSS rollover using IDs which will changet he background image of the cell the mouse is hovering over.
The code is as follows.
In the stylesheet:
#divNav {
position: relative;
background-color: #000000;
background-repeat: repeat-x;
background-image: url(images/nav_background.jpg);
width: 1000px;
height: 22px;
top: 0px;
text-align: center;
cursor: default;
#divNav a:link, a:visited {
border: 0;
text-align: center;
vertical-align: top;
color: #ffffff;
background-color: transparent;
background-repeat: no-repeat;
font-family: Verdana, Arial, Helvetica, sans-serif;
font-size: 12px;
width: 150px;
height: 22px;
#divNav a:hover, a:active {
border: 0;
text-align: center;
color: #ffffff;
background-image: url(images/nav_over.png);
font-size: 12px;
width: 150px;
height: 22px;
cursor: pointer;
And on the page:
I know it's wrong, but I've tried moving the id="divNav" to several different places knowing the the style is applied to the children of the object that you set it to, not the object itself, but it didn't work anyway.<table width="100%" border="0" cellpadding="0" cellspacing="0" height="22">
<tr>
<td id="divNav"><a href="#">Home</a></td>
<td id="divNav"><a href="#">Themes</a></td>
<td id="divNav"><a href="#">Wallpapers</a></td>
<td id="divNav"><a href="#">Sounds</a></td>
<td id="divNav"><a href="#">Software</a></td>
<td id="divNav"><a href="#">Support</a></td>
</tr>
</table>
Thoughts?
Edit: Also, the "noparse" BB tag on these forums doesn't work.
Edit edit: Nor does the [code] tag.
Edit edit edit: And placing code in [quote] tags won't show the code either.
