Results 1 to 11 of 11
Thread: Need advice on a new build using an overclocked bundle.
    Nov 2010
    70
    Default Need advice on a new build using an overclocked bundle.
    I am planning on buying ta 49478 bundle, which is Gladiator Intel i5-3570K 4.40GHz Pre-Built Overclocked Gaming Bundle (Ivy Bridge) and I was wondering if the following components will be compatible with it:
    • 24" Iiyama Prolite E2473HDS Widescreen LED Monitor
    • Fractal Design Define R3 Black Pearl V2 Midi Tower Soundproof Chassis
    • Samsung SH-B123L/BSBP 12x BluRay ROM / 16x DVD±RW Lightscribe SATA-II Optical Drive - Black (OEM)
    • 650W Corsair TX650 V2 80PLUS Bronze Power Supply
    • 1TB Seagate ST1000DM003 Barracuda 7200.12 SATA III 6Gb/s Hard Drive - HDD
    • Mushkin Chronos 120GB 2.5" SATA-III Solid State Hard Drive
    • MSI HD 7870 Twin Frozr III OC 2048MB GDDR5 PCI-Express Graphics Card
    Thank you in advance.
    May 2012
    Somerset
    950
    297
    I would have said so, but I would have considered personally a better PSU.. Corsair has a much better unit like the HX or the AX and they would be better to use than the TX with all that hardware. I might consider a 750W as well but I don't think you'd need it. Only if you where going to add another 7870 or get something bigger to replace it..
    Moderator Spaceboy's Avatar
    Aug 2010
    Leicester
    14,809
    3,251
    Excellent choices there all round, getting maximum bang for buck
    Swap the SSD for this one though : http://www.aria.co.uk/Products/Stora...roductId=44258
    And the TX650 V2 is an awesome PSU already mate, no need to swap it imo.
    You're all set, I think, bang on the money
    Quote Originally Posted by nft99 View Post
    They dont let me in the shop
    If you open your mind too much, your brain will fall out
    Fractal R3, Core i5 3570k, z77x-d3h, 8gb exceleram, GTX460
  4. The Following User Says Thank You to Spaceboy For This Useful Post:
  5. #4
    May 2012
    Somerset
    950
    297
    I apologise I didn't even see the SSD!! I'd also suggest the M4's, they are awesome Two 64Gb models are on the way for me!!
  6. #5
    Nov 2010
    70
    Thank you for the advice guys, ordered 1 minute ago and swapped SSD.
  7. #6
    Aug 2010
    Leicester
    14,809
    3,251
    Quote Originally Posted by Vladimir View Post
    Nice! Pics when it arrives
  8. #7
    Nov 2010
    70
    will do
  9. The Following User Says Thank You to Vladimir For This Useful Post:
  10. #8
    May 2012
    Somerset
    950
    297
    When do you expect delivery??
  11. #9
    Nov 2010
    70
    I have no idea, it says on the website to allow 10 days for a bundle. So i guess it will take about 10 days from today, not sure about all other components though maybe they will send them separately. So I think next week is the most likely scenario.
  12. #10
    May 2012
    Somerset
    950
    297
    Oh right, well when it does I do look forward to seeing the pics and the build I'm sure that you'll be very impressed
  13. #11
    Systems Repair Wizard. PatrickC's Avatar
    Feb 2012
    The Moon
    631
    16
    Up to 10 working days from the day of purchase. The latest it could arrive is the 21st of May.
    GL HF
    Currently Playing
    Dota 2 | Injustice Gods Among Us
