Page 2 of 2 FirstFirst 12
Results 16 to 23 of 23
Thread: Best bang for buck?
  1. #16
    Boomstick777's Avatar
    Jul 2010
    Devon
    3,672
    614
    Quote Originally Posted by gavbon View Post
    7850 or if your lucky, gtx480 SLI if you can bag £100 per card
    Getting well over 100fps with GTX 480 SLI and 3770K on BF3! 480's are still good performers and value if you can find cheap used cards.
    Also the GTX 670 is shaping up to be a nice card, probably come in at closer to £300 though...
    Main Rig: i7 3930K|GTX 660 SLI|32GB DDR3|2x 240GB SSD RAID 0 + 2TB|Gigabyte X79 UD5|850W CM SilentProM|27" Shimian LED-IPS QLITE 1440P|
    Steam Box: Xeon 1230 V2|HD 7850 2GB|16GB DDR3 2133mhz|120GB SSD + 240GB SSD|Gigabyte X68|550W Antec PSU|46" Samsung LED LCD|
  2. #17
    MixtaMike's Avatar
    Apr 2012
    Norfolk
    625
    55
    I picked up a 6950 XFX Double D for £170 and spent the rest on better bits
  3. The Following User Says Thank You to MixtaMike For This Useful Post:
  4. #18
    May 2012
    22
    7850 without question, decent stock and excellent OC performance, but the clincher is the lower temps, noise and power draw for the same performance. Plus you have to think there will be more headroom moving forward for the 7850 being newer tech.
  5. #19
    almighty15's Avatar
    Mar 2011
    Wolverhampton
    3,205
    277
    7850 for the win, or if you can stretch to it, a 7870..
    Join the fan page -
    https://www.facebook.com/SubZeroPcCooling
  6. #20
    May 2012
    22
    At current prices I reckon the 7850 still represents a better bang for buck than the 7870 as it is almost 50% more expensive.
  7. #21
    PC Guru dirtylarryuk's Avatar
    May 2011
    UK
    1,347
    64
    Quote Originally Posted by Double07 View Post
    Till the 660 arrives AMD can still coin the mid range. Current prices should chnage a bit and perhaps more free games etc once a alternative from Nvidia arrives.
    GAMES 3D: i7 2600k 4.9Ghz, P67, FT02 SE, Gigabyte Titan, 4GB DDR3, 256GB M4
    OCZ Revo 2 x2 PCIE SSD 240 GB, G930 7.1. DISPLAYS: 2D 27" IPS 60Hz Dell 1440p 6ms U2711 - 120"
    21:9 100Hz DLP 0.1ms, 29" Dell IPS 60Hz 29" 21:9
  8. #22
    almighty15's Avatar
    Mar 2011
    Wolverhampton
    3,205
    277
    Quote Originally Posted by dirtylarryuk View Post
    There no figures at all for the 660 so it's impossible at this moment in time to say I'd it will it won't be the best bang per buck card.
    Join the fan page -
  9. #23
    May 2011
    UK
    1,347
    64
    Quote Originally Posted by almighty15 View Post
    Indeed but it would be pretty safe to say it will be like the current AMD cards may be slighty worse or slighty better but it will effect their price and special offers when it arrives. In the meantime plenty of amazing offers on old 40nm cards may tempt some buyers but the smart cash looks at 28 dues to extra features and VRAM in many cases. A growing list of games would play great on a 570 but would look better on a 7850 2GB. And if the 670 is £300 after launch that's going to temp alot of people and we may see the 7970 hit £300 as well. If we really see 670-7970 for £300 that mega power for the cash (that would also effect the mid range cards prices as well so 7850 2GB should then below £150).
