Thread: DBAN not working?
    Feb 2012
    53
    Default DBAN not working?
    Hello,
    I am trying to remove everything on my hdd and restart from fresh so I can solve my GPU problem.
    I've tried putting in windows 7 and I get an error.. I then tried DBAN and I get an error saying "the disks have not been found" plus press and hold the power button.
    Any other programs I can use to reset everything?? Or a way to get around DBAN
    St.Helens
    288
    66
    Whats DBAN?
    Try an install from pen drive.
    flyboyovyick
    AMD Llano A8-3870k 3Ghz|Cooler Master Hyper 612s|ASUS F1A55-M LE Motherboard
    Kingston HyperX Blu 8GB 1600MHz DDR3|Seagate Barracuda 2TB 7200RPM HDD
    Radeon HD 6550D OC'd @ 800Mhz|Windows 8 Pro 64bit|NZXT M59
    Packard Bell Viseo 23" FullHD LCD|LOGITECH G15 \m/ and a MX518 mouse.
    Feb 2012
    53
    It wipes your HDD.
    Tried that and no luck
    Best viewed in moderation
    Mar 2012
    6,068
    1,545
    Ubuntu Live OS, format the drive through that, delete the partition and create a new NTFS one?
    Corsair 600T | Asus Sabertooth Z77 ATX | Intel i5-3570k | Corsair H100i | Corsair Vengeance LP Black 16GB | EVGA GTX670 2GB | PNY GTS250 512MB | Mushkin Chronos 240GB
    St.Helens
    288
    66
    Why do you need to format it?
    It does it when installing windows.
    flyboyovyick
    Banned
    May 2010
    Liverpool
    7,407
    692
    as said just use the windows cd
    never used a 3rd party program to format a drive
    if thats giving you an error either the drive is on its way out OR the optical drive is having issues reading the CD
    spleenharvester's Avatar
    Dec 2009
    West Midlands
    2,234
    704
    Unplug optical drives, card readers etc.
    If you're not planning on selling it, I'd just reformat, personally.
    Toshiba L300 | Intel T2370 1.73GHz | GMA X3100 | 2GB RAM | Crucial M4 64GB | Windows 7 Home
    Death From Above Jacksb4's Avatar
    Sep 2011
    Southampton-ish
    3,674
    710
    Kiildisk is your friend here
    I5 2500K @ 4.2GHz| MSI Z77 GD65 | 8GB Predator DDR3 | Radeon 5850| BeQuiet! L8 630W | CoolermasterWavemaster
    Razer Lachesis | Razer Black Widow
